Shortcut for hooking up speedo cable to speedo?
Old Oct 16, 2004 | 12:40 PM
Krakkles's Avatar
Default Shortcut for hooking up speedo cable to speedo?
ZC in 91 Si, Si tranny.
I think I've narrowed down my speedometer problems to my connection at the speedo, as some people suggested. Reason being, the VSS (and cable) are able to pull away from the car 6 inches or so pretty easily, and when spinning the VSS pinion manually, a sound can be heard at the dash, but only when the cable is not "pulled away".
So, I looked in my Haynes, and pulling apart the dash / console to fix this is not something I want to do. I'm wondering if I can maybe stick a tube over the speedometer cable and fish the connection back on through the firewall? Or, can I cut a hole in the firewall to reach it? Can I go in from under the dash somehow?
What can I do?
Old Oct 16, 2004 | 01:10 PM
CRX_Control's Avatar
Default Re: Shortcut for hooking up speedo cable to speedo? (Krakkles)
mabe you can ziplock it down so that there is no movement?
Old Oct 16, 2004 | 01:23 PM
Krakkles's Avatar
Default Re: Shortcut for hooking up speedo cable to speedo? (CRX_Control)
I'm pretty sure it's disconnected at the speedo.
Old Oct 16, 2004 | 02:14 PM
1 Cam Wonder's Avatar
Ya Im an idiot to man
I dropped my tranny and didnt even ******* remember to disconnect it
I was having trouble getting it out (absolutely couldnt get it out) so I moved on, drop the tranny and SNAP!!!
******* broke on me, now I dont know how fast Im going
Pissed me off how hard they are to install so Imma keep track of this thread and bump it to ****
JJGL-EF90
Dec 20, 2010 09:23 AM
1kleenef
16
Feb 14, 2007 12:11 PM
norcal450
Jan 5, 2007 03:10 PM
LudeJdm
14
Jul 12, 2005 04:56 PM
rasta420
Jul 7, 2002 07:50 PM
