turbo kit "peace one together or get the kit"
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicext »</TD></TR><TR><TD CLASS="quote">well my budget is high cause i still have to build my motor and get my head done for the turbo.. i have alot of time to wait if need so to get what i need for the build up. first build up i have done and i want to tike my time with it.</TD></TR></TABLE>
peice it together for sure..
piece it together. Look at other people's set up and follow their suit. MOst people are using T3/TO4E .50 or.57 trim turbos or using the Precision SC34 or SC61 trim turbos.
Depends on what your application is and what your goals are but I say piece it!
Even if you have a high budget, you should just piece it together because in the end, you'll have the satisfaction of knowing that you put together the setup yourself rather than buying an off the shelf turbo kit.
well i do not know why you have to call someone a "jaskass" for an account that i did not have no controll over i went through the steps like you had to and it gave it to me it us a name i use in other room so i used it.. it is an onest mistake but i have no control over what a computer dos.. and it is not like i went to all the room startering **** with people i here! i here ask for advise and give it if i can help people. i here to have fun but this is my new new name if this is not taker? the board still has to look at it to give the ok for my to give the ok unless some has this name but i did post this under civicext but if this is going to be an problem in the board they need to address it asap here my new name if you want to hit me back
CustomX113
Nov 20, 2006 09:27 AM
