Very Detailed Cluster Problem-Yea, I searched.
Old Oct 15, 2004 | 11:44 PM
Slow89HB's Avatar
Default Very Detailed Cluster Problem-Yea, I searched.
Okay, here we go. Car is an 89 STD Hatchback. I bought an either 88 or 89 CRX cluster and installed it. Everything works, except for one problem. The temp gauge moves up and past the H(ot), this is just when putting the key in the acc position, and stays up there while driving. The temp gauge is supposed to be green/yellow wire. This wire goes into the last position on the larger male connector (pos. 12). Ive read a few pin out pages and none of them seem to be helping me. Most of them say the green/yellow wire is supposed to be in spot #3, but the one that is there is white/yellow, which is supposedly the fuel gauge, and my fuel gauge works perfectly. What I guess I need is a pinout from an 88-89 crx, and the pinout from a std. I made sure the copper on the back was clean, and am at a ******* loss for words. If anybody can help, it'd be greatly appreciated. The std. Cluster's temp gauge works fine. Heres some pictures as to draw in more people.
Old Oct 16, 2004 | 12:10 AM
2point2's Avatar
Default Re: Very Detailed Cluster Problem-Yea, I searched. (Slow89HB)
Weird.. Did you buy this strait from the autowreckers? the only thing i can think of is the needle being in the wrong spot (from someone fooling around with it).
unplug the wire or sensor and see if it temp needle goes limp. The pinouts should be the same within 88-89 and 90-91 (someone correct me if i'm wrong).. if you swapped a cluster from a new car many things wouldn't work. So, it either works or it doesn't.. never heard of just one part of the cluster not working because of pinouts?
Old Oct 16, 2004 | 12:41 AM
Slow89HB's Avatar
Default Re: Very Detailed Cluster Problem-Yea, I searched. (2point2)
Yes, I did. Il unplug the wire from the sensor tommorow. If I unplug the wire in the #12 spot, (green/yellow), and it goes limp, where should I go from there?
Old Oct 16, 2004 | 01:16 AM
kruthles's Avatar
The same thing happened to me when I had a bad ground on my valve cover, you could start by checking your grounds...
Old Oct 16, 2004 | 02:31 AM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
Default Re: (kruthles)
maybe ur temp gauge wire and ur fuel gauge wire are mixed up? do u have a full tank of gas? because on ur fuel gauge, isnt that where ur cars temp. would be when hot?
Old Oct 16, 2004 | 03:25 AM
B16CRXT's Avatar
Default Re: (b2o-vtec)
Replace the thermostat.
Old Oct 16, 2004 | 04:22 AM
crx_88_si's Avatar
lol my 88 crx does this too..
i find when i hit a decent bump it falls down to normal. THen i found that if i smack the top of the cluster cover it comes down too. (sometimes).
try smackin the cluster.
Old Oct 16, 2004 | 05:05 AM
92integra_gs's Avatar
just buy a new cluster....
Old Oct 16, 2004 | 06:10 AM
b16_madman's Avatar
If you have your old cluster still, given it's the same kind. If you can salvage your temp/fuel from it, just swap those two out.
or get a new cluster
Old Oct 16, 2004 | 07:20 AM
Patch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kruthles &raquo;</TD></TR><TR><TD CLASS="quote">The same thing happened to me when I had a bad ground on my valve cover, you could start by checking your grounds...
Old Oct 16, 2004 | 08:12 AM
90JPRCRX's Avatar
Smells like Tuna
Default Re: (Patch)
hey my 88 crx does that too....
except its cuz my car really gets that hot hehe
Old Oct 16, 2004 | 10:39 AM
Slow89HB's Avatar
Default Re: (88JPRCRX)
Disconnected these wires
Still got the same results...where should I go from here?
Bonus pic!
Old Oct 16, 2004 | 11:16 AM
Slow89HB's Avatar
Default Re: (Slow89HB)
Okay, update...When I unplugged the wire from the block, the temp guage still went to hot, when I took out the green/yellow pin in spot #12, the temp gauge didnt move at all. I tried putting the old cluster in, and for some reason only worked when the smaller plug wasnt plugged in. Heres a comparison shot of the back of the cluster, the large plug.
New Cluster-
Old Cluster -
Large Plug-
Old Oct 16, 2004 | 01:17 PM
DieMaster's Avatar
Needs to be About 20% Cooler
first that pic is of ur revrise lights swich . second i had a high or hot gauge too and it was a bad ground under the dash and my temp sender had a intermeatie (?) conection
90si-rex
Jul 7, 2014 02:17 PM
ALDJ253
Mar 7, 2014 09:09 PM
bighoss77
Jul 21, 2012 03:55 AM
SpEcIaLkOuPe
Apr 25, 2009 12:58 PM
b16a1eg6
Oct 5, 2007 03:16 PM
