25mm front sway bar on 93LX?
I’m getting ready to purchase the energy suspension master kit, engine torque mount, and sway bar mounts. What else do I need since I am also replacing my shocks with Tok Illumina kit. A few sites list the front sway bar body mounts as 25mm but according to energy suspension I should always measure mine. Well I tried, but not having a caliper makes it difficult to get an accurate measurement. Can anyone tell me if it is safe to assume that the 93LX has a 25mm front sway bar?
Would a 93 EX,SE rear sway bar fit on a 93 LX? It does look like its got the mounting holes for the bar on the body and holes on the trailing arm for the links. Has anyone tried this? I think the ex, se has disc and the lx ha drum brakes, so is this why it would not fit? Can't afford a ST rear swaybar right now and would like to experiment with a EX/SE rear swaybar (abt. $35 used).
Thanks!
Arv
Thanks!
Arv
idk what the front sway bar for the lx is... not that it really matters if you're getting an aftermarket sway bar.
i would assume it's 21 mm, but i may be wrong.
the ex rear sway bar will fit, but you'll have to drill holes, as the lx trailing arms do not have the holes pre-drilled.
i would assume it's 21 mm, but i may be wrong.the ex rear sway bar will fit, but you'll have to drill holes, as the lx trailing arms do not have the holes pre-drilled.
I did the crecent wrench getto caliper measurement and its about 22mm, maybe a little thicker but 22.5mm max. So I guess I'm getting 22mm bushings, right?
Thanks for the info on the rear sway bar. I think my 93 LX trailing arms have the holes for the sway bar links. There is a hole in the area (uppper part of trailing arm) where its supposed to go to but I'm not sure if its the one.
thanks
Arv
thanks
Arv
