My car too heavy to be quick????????
hey whats up guys I have a 92 GSR (setup in sig). last time I was at the track the car weighed in at 2700 lbs wit me in it (155lbs). I am currently working on a new setup for my car. Do you think its worth it in a 2700lb car? Is my car too heavy to be a quick all motor car.? I would like to run like 13's but my car is really a pig. is it possible to run 13's with a good all motor setup or will I have to get a hatch to see those types of times? Im not sure if I should sell my car because of weight issues or if I should just go with like a B20 set up or something for more power. Any advice, criticism and feedback always appreciated. Thanks guys
You can run 13's all motor with a heavy car. When my coupe was a pig (at least 2650, if not more) I was running mid-13's with 200 whp.
I only ran at the track 1 time so Im a beginner and I ran best 0f 15.5 with 2.5 60' and 92 mph trap speed. I had some shitty *** tires on full psi and 2700lbs. I need to work on 60' bad but I need some practice at the track. Just wondering if my heavy *** pig had something to do with those crappy times. I was hoping to do much better
I actually just went to watch but then I was told that I didnt need helmet tpo run so I said what the hell and just raced my car without any preparation or track experience. but yeah, that was my best time
sounds like he was running a b18c. my car is 1.7. what type of weight reduction did he do? was it all motor? Nitrous?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 8000KReV »</TD></TR><TR><TD CLASS="quote">hey what type of setup were you running?</TD></TR></TABLE>
84mm GSR motor 11.5:1 JE pistons, Skunk Stage 2's, DC JDM 4-1 header, ITR IM, 70mm TB, chipped ECU, 22x8x13 M & H's.
Having a heavy car doesn't mean that it can't be quick. It just means that you need more power to get a given level of performance. In other words, you can get 13 seconds. But it is going to be harder to get there than it would be with a CRX.
you can go 12's my car is a 94 integra gsr and im heavier i weight 200lbs and my car weigh 2648lbs and my car runs 12.60's all day.i recommend an ls/vtec set-up that has around 210 and 140 torque @ wheels will make it happend and also with a good suspension too.If you need help email me at lsrteg@yahoo.com i have a good friend who can build you one and my motor is stock block with ctr pistons only on a gsr block with type-r head only 1.8 will do the job ok
ringgold
May 2, 2004 04:42 PM
