where to buy a ss pipe cutter
Old Oct 15, 2004 | 03:24 PM
RACEPAK's Avatar
Default where to buy a ss pipe cutter
hello everybody
for a while now i'm looking a reliable chain pipe cutter that will cut stainless. 2"-3.5"
where can i buy this tool?
keep up the good work
Old Oct 15, 2004 | 03:57 PM
Adriano's Avatar
Default Re: where to buy a ss pipe cutter (RACEPAK)
Any plumbing store should have them. Even home depot or loews will have them.
Old Oct 15, 2004 | 05:59 PM
project dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RACEPAK &raquo;</TD></TR><TR><TD CLASS="quote">hello everybody
keep up the good work </TD></TR></TABLE>
jc whitney got em but they dont cut stailness. i gotta use my bandsaw to cut stailness crap =T
Old Oct 15, 2004 | 08:14 PM
oxSLEEPERxo's Avatar
Default Re: where to buy a ss pipe cutter (project dc2)
how well does that chain pipe cutter works?
Old Oct 15, 2004 | 09:14 PM
RCautoworks's Avatar
Default Re: where to buy a ss pipe cutter (oxSLEEPERxo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oxSLEEPERxo &raquo;</TD></TR><TR><TD CLASS="quote">how well does that chain pipe cutter works?</TD></TR></TABLE>
Also wondering, I was gonna use a sawzal or a cutting disc but will this produce a better cut ?
Old Oct 15, 2004 | 09:38 PM
h22mark's Avatar
You could also use a "whiz wheel" if you have a compressor
Old Oct 15, 2004 | 09:57 PM
Default Re: (h22mark)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22mark &raquo;</TD></TR><TR><TD CLASS="quote">You could also use a "whiz wheel" if you have a compressor</TD></TR></TABLE>
Whats a whiz wheel ? Is it like a cutting disc ?
Old Oct 16, 2004 | 11:18 AM
Evil Empire's Avatar
Default Re: (90blackcrx)
What about a Chop-Saw ???
I use my chop-saw for all kinda misc jobs
Old Oct 16, 2004 | 11:56 AM
Bnjmn's Avatar
Default Re: (Evil Empire)
A chop saw/mitre saw is the best. You can get a fiber cutting disc in just about any size. Depending on the size of the pipe you are cutting- you may have to make multiple cuts on the pipe (for like 3.5" pipe), but it is still the quickest/best way.
Ben
Old Oct 16, 2004 | 12:14 PM
Default Re: (Bnjmn)
Aren't a chop saw and a cutting disc basically the same thing, just one is handheld.
Old Oct 16, 2004 | 03:14 PM
Canuk_SiR's Avatar
agreed, chop saws are the next best thing to band saws.
Old Oct 16, 2004 | 09:31 PM
90DALS's Avatar
Default Re: (Canuk_SiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Canuk_SiR &raquo;</TD></TR><TR><TD CLASS="quote">agreed, chop saws are the next best thing to band saws. </TD></TR></TABLE>
i agree. i HAD to use a crop saw to cut some sched 40 T pipes for a manifold i was making. whiz wheel wouldnt do it, so chop saw it was.
Old Oct 17, 2004 | 08:12 AM
RACEPAK's Avatar
Default Re: (90DALS)
hello
i know i can use a chop saw/mitre/whiz wheel. but i dont have access to electricity or a compressor.
i need the chain cutter because in my neighborhood we have several gardens that has ss banister to lock on bicycles. nobody ever use it . so i might take it to make my exhaust and charge pipes.
Old Oct 17, 2004 | 08:45 AM
Bnjmn's Avatar
A cutting wheel (powered by an air compressor) will take forever and it'll be really really difficult to get straight cuts.
With a chop saw/mitre saw- straight cuts are a breeze and cuts are done in seconds.
Plus cutting with an air powered cutting wheel will get expensive since you'll go through a number of discs.
Old Oct 17, 2004 | 12:09 PM
98AccordEX's Avatar
Default Re: (RACEPAK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RACEPAK &raquo;</TD></TR><TR><TD CLASS="quote">i know i can use a chop saw/mitre/whiz wheel. but i dont have access to electricity or a compressor.
i think a hacksaw would be your best bet then. with the chain cutter you can only cut straight cuts. when you make exhaust that doesnt always work
Old Oct 17, 2004 | 12:24 PM
Default Re: (Bnjmn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bnjmn &raquo;</TD></TR><TR><TD CLASS="quote">A cutting wheel (powered by an air compressor) will take forever and it'll be really really difficult to get straight cuts.
Plus cutting with an air powered cutting wheel will get expensive since you'll go through a number of discs.</TD></TR></TABLE>
See I was talking about the electric ones, the disc seem to last pretty long also.
Old Oct 18, 2004 | 03:17 PM
RACEPAK's Avatar
Default Re: (98AccordEX)
thank you everybody
eventually i used a hack saw.
$1 hack saw + $1 (2) stanley saws = free ss pipes = 1 happy tuner
Old Oct 18, 2004 | 03:48 PM
shortyz's Avatar
i never use my bandsaw to cut over 2" exhaust pipe, unless u go really slow itll bit the pipe hard half way through and rip teeth off the blade. even on 40$ blades.
which is why i use a chop saw now
Old Oct 21, 2004 | 11:04 AM
twkdCD595's Avatar
Default Re:
has anyone tried those chain cutters, seems like it would be a tedious process on thicker material. (EDIT: just read about your piping find... LOL...)
my bandsaw has no problem with any piping and if you can afford one now I suggest it... sawzall gets too frustrating after a while, and I hate trying to cut straight with the cut off wheel plan.
shortyz: you should try buying the finest tooth blades you can, and take some pressure off, slow the cutting down through the cut section that was tearing up blades.
Old Oct 23, 2004 | 07:13 PM
Calvinator's Avatar
Use the Sawzal
Old Oct 24, 2004 | 06:15 AM
ManBearPig4silly's Avatar
Shorty def get a much finer blade and go as slow as is possible. That should not happen. Horz bandsaws own.
Old Oct 25, 2004 | 11:07 AM
twkdCD595's Avatar
Default Re: (silly4lude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silly4lude &raquo;</TD></TR><TR><TD CLASS="quote">Shorty def get a much finer blade and go as slow as is possible. That should not happen. Horz bandsaws own.</TD></TR></TABLE>
werd and if it like mine you can lock the top assembly upright and use it as a vertical also.
z395civic
Nov 16, 2008 06:35 PM
jbrick28
Mar 17, 2007 08:00 PM
Ca$h
Feb 17, 2004 07:58 PM
k193sup
May 22, 2002 07:38 AM
Chip398193
Apr 2, 2002 05:48 AM
