Blinker will not work in 03 civic
Old Oct 15, 2004 | 10:02 AM
Deerslayer's Avatar
Default Blinker will not work in 03 civic
I installed a Alpine mp3 player in my 03 civic and the blinkers will not work. I checked the fuses and they were fine. Could this be a bad flasher? If so, were is it located. Someone said that the 4 way switch might be unplugged. Were is this located?
Old Oct 15, 2004 | 03:22 PM
Jim Truett's Avatar
Default Re: Blinker will not work in 03 civic (Deerslayer)
Did you unplug the connector from the hazard switch, and forget to plug it back in?
Old Oct 17, 2004 | 09:29 AM
PrettyLude's Avatar
Jim Truett your probably right, does it not work on both sides? if that's the case, plug up the emergency hazard switch
bluelights81
Dec 25, 2013 08:04 PM
patpeery
25
Apr 9, 2008 06:51 PM
imreal
Mar 8, 2008 08:27 AM
Swapped_EG
Nov 25, 2006 08:10 AM
