ABS question, probably a dumb one.
Old Oct 15, 2004 | 07:05 AM
khenning's Avatar
Default ABS question, probably a dumb one.
Hey, I did some brake work and now my ABS light is on. I have noticed that my abs resevoir is low. I would like to add some fluid but I wanted to make sure that it is just brake fluid used. Could anyone confirm this? By the way I have a 96 EX Vtec.
Old Oct 15, 2004 | 09:20 AM
newdad's Avatar
Default Re: ABS question, probably a dumb one. (96vtec)
yeah is regular brake fluid honda dot 3 recommended, and that will make the abs light come on make sure it dosent have any cracks also check if the pump is running even when car is off... if that happends you have to replace the acumulator and the actuator and thats not cheap so i hope that is not the case good luck
Old Oct 15, 2004 | 11:33 AM
khenning's Avatar
Default Re: ABS question, probably a dumb one. (newdad)
Thanks for the help. That seems to have taken care of it.
90teg
May 2, 2006 08:20 PM
Solipsist
Jan 27, 2004 09:33 AM
social_control
Jul 23, 2003 07:36 AM
LarryBird
Jul 9, 2003 01:13 PM
