My fuel pressure is f***ed up. Its stuck at 44psi.....ALWAYS.
Old Dec 17, 2001 | 05:21 AM
JM Performance's Avatar
Default My fuel pressure is f***ed up. Its stuck at 44psi.....ALWAYS.
Ok, I finally got my turbo installed, but I'm having a problem w/ the fuel pressure.
I installed the B&M FPR. Now my fuel pressure is a constant 44psi, no matter what I do. Vacuum on, or off or how much I turn the screw...its still 44 (well, shaking between 42 and 46). I think I'm leaking fuel at my B&M fp gauge, but a very little bit. Could that cause the problem? BTW, my fuel setup is Walbro intank, bm fpr, and 2 extra injectors tapped outta the line from the rail to the filter.
Thanks.
Old Dec 17, 2001 | 06:20 AM
GSRwBOOST's Avatar
Default Re: My fuel pressure is f***ed up. Its stuck at 44psi.....ALWAYS. (00SilverLS)
question:
do you have an inline pump?
i'm asking because if you have the fpg between the pumps it wont read correctly... (i did that and have changed it or in the process today, i love callling in sick off work for car ****.. )
a small fuel leak isn't good, but shouldnt cause it to stay at one spot unless you don't have an fmu either... then your fuel pressure will stay almost the same i believe...
Old Dec 17, 2001 | 06:27 AM
rtype11's Avatar
Blocked fuel return line???
Old Dec 17, 2001 | 12:11 PM
HKxBlur's Avatar
is it possible that the screw isn't touching the vacuum adjustment? Maybe the FPR was put together wrong? hmm..
Old Dec 17, 2001 | 01:10 PM
Default Re: My fuel pressure is f***ed up. Its stuck at 44psi.....ALWAYS. (HKxBlur)
Nah, I think I figured it out. I think my pump is overpowering the diaphram. I need to drill a relief hole. Like this: http://www.theoldone.com/articles/regulator/
Old Dec 20, 2001 | 01:05 AM
HKxBlur's Avatar
That doesn't sound right.. The relief hole is if there's *too much* pressure like 60psi or something, and u need 50.. You not being able to adjust the pressure is the problem and if u do indeed have leaks of any kind, this can very well be the problem.. hopefully the fpr was put together properly (i'd reinstall it), and then mated to the rail with no leakage..
Old Dec 20, 2001 | 02:53 AM
Well, sorry HKxBlur, but I drilled a 1/32" hole and now it works perfect. 38psi at idle and like 44 at wot.
Old Dec 20, 2001 | 03:12 AM
Arturbo's Avatar
Better than steak
25 Year Member
Put the stock one back in...
art
Old Dec 20, 2001 | 05:07 AM
Default Re: My fuel pressure is f***ed up. Its stuck at 44psi.....ALWAYS. (Arturbo)
art
Why? Its fixed.
Old Dec 20, 2001 | 05:22 AM
Arturbo's Avatar
Better than steak
25 Year Member
thats what I get for not reading the entire post..
art
Old Dec 20, 2001 | 12:39 PM
brinks's Avatar
Get some teflon pipe sealant on that fuel pressure gauge to stop the leak.
Old Dec 20, 2001 | 01:52 PM
TeggerLS's Avatar
New User
How's the car running? Did you run it at E-town yet? and how much did the Turbo set you back? Who installed it, and how much? Sorry bout all the ?'s
Old Dec 20, 2001 | 01:57 PM
Default Re: My fuel pressure is f***ed up. Its stuck at 44psi.....ALWAYS. (TeggerLS)
Car's running good, but slow. I need an exhaust and tuning. I'm running hella rich. The turbo cost 3250, but after everything it looks more like 5500. And, yeah, I installed it.
Old Dec 20, 2001 | 02:00 PM
TeggerLS's Avatar
New User
Damn! I was thinking of going turbo, but at that kinda money I think i'll be getting a house 1st Probably gonna get the head P&P in the spring/summer. So how you been? Everything going well? I lost AOL btw, my AIM name is TeggerLS96 if you ever want to drop a line. Did you get a time? I race you, w/ my poorly tuned N2O L8R
Old Dec 20, 2001 | 03:51 PM
HKxBlur's Avatar
Great! Glad to see it's all fixed..
Can u be absolutely positive that there wasn't something stuck in there, or put together wrong, or something.. Main thing is that everything's cool, but just wondering how the relief fixed your symptoms.. I don't get it..
jman86
Nov 7, 2024 12:19 PM
solattack77
Mar 30, 2011 11:38 AM
Shmaa
Jul 7, 2006 04:59 PM
boostaholic
Jun 30, 2002 07:25 PM
b18c1-ek
May 29, 2002 04:44 PM
