did not clay my b20vtec
Old Oct 14, 2004 | 07:51 PM
b20izzle's Avatar
Default did not clay my b20vtec
im running a b20vtec with 11.5:1 je pistons, itr cams, on a gsr head with stock valves. the motor is already in my car and its been running. now will i run into problems later on if i upgrade my cams or is the pistons okay for my setup?
Old Oct 14, 2004 | 10:36 PM
b20izzle's Avatar
Default Re: did not clay my b20vtec (b20izzle)
searched and nothing about aftermarket pistons...but i am assuming im okay cuz the pistons were meant for a vtec head.
Old Oct 15, 2004 | 07:35 AM
racecarpete's Avatar
It really depends, has the head been milled, block decked? You might run into problems if you upgrade your cams later. In my opinion, you should ALWAYS check all tolerances including claying the motor. Cams are not just a bolt in affair like most people think, there is a little more precision to it.
Old Oct 15, 2004 | 08:09 AM
b20izzle's Avatar
Default Re: did not clay my b20vtec (SilverCivic2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverCivic2k &raquo;</TD></TR><TR><TD CLASS="quote">It really depends, has the head been milled, block decked? You might run into problems if you upgrade your cams later. </TD></TR></TABLE>
no its just been sleeved thats all. when i get my new cams i will clay it.
SR20S13
Feb 23, 2010 06:27 PM
Dave_Dc2
Nov 23, 2008 09:21 PM
Boosteddb8
Aug 20, 2006 02:27 PM
ACrite3404
Jan 24, 2005 10:58 PM
TmeX05
Dec 29, 2002 09:55 PM
