h23 manual tensioner
Old Oct 14, 2004 | 05:08 PM
darkd1gt's Avatar
Default h23 manual tensioner
what store can i get one from car quest advance auto? i called auto zone they said they couldn't even get one. i know where there is a wrecked car with one at but how hard would it be to get out price wise cause the junk yard wont let u pull the parts?
Old Oct 14, 2004 | 07:02 PM
Prolink's Avatar
Default Re: h23 manual tensioner (mattspivey)
a manual tensioner for what?
Old Oct 14, 2004 | 07:19 PM
matix's Avatar
Default Re: h23 manual tensioner (Prolink)
Honda is the only way to get it. Its a oem part. Goto http://www.hondaautomotiveparts.com if you wanna order it.
Old Oct 14, 2004 | 08:10 PM
SKDRCR's Avatar
Default Re: h23 manual tensioner (matix)
Parts list:
13404-PT0-004 - ADJUSTER COMP., BALANCER BELT
13415-PT0-000 - BRACKET, BALANCER BELT ADJUSTER
14510-PT0-004 - ADJUSTER COMP., TIMING BELT
14516-PT2-000 - SPRING COMP., TIMING BELT ADJUSTER
14521-P14-A00 - PLATE, ADJUSTER
90014-P14-A00 - BOLT, TIMING BELT ADJUSTER BASE
90015-PT0-000 - BOLT, TIMING BELT ADJUSTER SPRING
90016-PT0-000 - BOLT, TIMING BELT ADJUSTER
90140-P14-A00 - WASHER, PLAIN (11MM)
Here is a link for the parts list:
http://www.hondaautomotivepart...82%29
There are the oem part#'s j00 need
Old Oct 15, 2004 | 07:26 PM
darkd1gt's Avatar
thanks for the help guys i got it from carquest they have the hook up on all the parts lol it came with the one for the tb and the bb
Old Jan 4, 2005 | 05:42 PM
OzWolfbane's Avatar
Resurrection !!!!
Guys can i use any parts of my current H23 for this (the expensive ones ?? ) im doing a swap
Old Jan 4, 2005 | 06:06 PM
Turbogixxer's Avatar
Default Re: h23 manual tensioner (OzWolfbane)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OzWolfbane &raquo;</TD></TR><TR><TD CLASS="quote">Resurrection !!!!
Guys can i use any parts of my current H23 for this (the expensive ones ?? ) im doing a swap</TD></TR></TABLE>
Yes, You should get a new adjuster and springs. Adjuster is most of the cost.
Old Jan 4, 2005 | 06:15 PM
OzWolfbane's Avatar
IS the adjuster same as H23 ? If it is any paticular reason i cant use it ?
Old Jan 4, 2005 | 06:27 PM
Default Re: (OzWolfbane)
F-series and H-series manual tensioner are the same. H22a use a auto. I said you SHOULD get a new one (aka If you are doing a H23a manual tensioner convention on your H22a, yes, your h23a parts will work). It is a bearing too. It can fail. Springs too.
Old Jan 4, 2005 | 06:56 PM
H_doubledeuce_A1's Avatar
Default Re: h23 manual tensioner (SKDRCR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SKDRCR &raquo;</TD></TR><TR><TD CLASS="quote">Parts list:
There are the oem part#'s j00 need </TD></TR></TABLE>
I'm running no balancing shafts on my H22a1 do I still need the Adjuster COMP. Balancer belt or no.
h22sedan
Nov 8, 2006 05:20 PM
snowblind7x
Jan 6, 2006 07:25 AM
antballs420
Jan 1, 2006 07:36 PM
skrewdlude
Oct 4, 2005 04:42 AM
93LudeVtec
Feb 3, 2003 06:15 PM
