B20/vtec setup ?
Old Oct 14, 2004 | 04:23 PM
KilaB18C's Avatar
Default B20/vtec setup ?
Checked my compression the other day and it didn't look good so I've deceided to build a bottom end. I was thinking about a B20 but my question is do I do every thing that you would do if it were a ls/vtec. Thanks
Old Oct 14, 2004 | 04:26 PM
wpgcivic's Avatar
please dont do b20 vtec, b20 blocks are super shitty, if anything do lsvtec
Old Oct 14, 2004 | 04:57 PM
na200whp's Avatar
Default Re: (wpgcivic)
b20 blocks are fine as long as you know ther limitations.good tunning and proper compression and it will be just fine.
Old Oct 14, 2004 | 10:55 PM
shorto85's Avatar
Dont rev a B20 block to high because it is basically a bored out B18 block so the cylinder walls are thinner and combined with the low R/S ratio your asking to shoot a piston through it if you rev to high.
Im going to be revving my LS/VTEC to 8000 RPM on a 82mm bore which should be pretty safe.
Old Oct 15, 2004 | 06:56 AM
wpgcivic's Avatar
unless you sleeve the b20 i wouldnt do it, they have super weak cylender walls
Old Oct 15, 2004 | 06:57 AM
wpgcivic's Avatar
my buddy is revving his lsvtec on stock bore all the way to 9+, and the whole setup cost him like 2 g's and is running 13.5
Old Oct 15, 2004 | 09:08 AM
ArinX's Avatar
Default Re: B20/vtec setup ? (KilaB18C)
do a little research, if its a mild build b20, you will be fine. Resleeving would be a good idea though.
speed_demon018
Jan 5, 2010 09:10 AM
immrtaltchnq
Oct 21, 2008 07:46 AM
Ole' B18
Dec 27, 2007 04:56 AM
b20turbovtec
Jul 21, 2004 10:19 AM
