TIG contamination question
Old Oct 14, 2004 | 01:14 PM
juicedse's Avatar
Default TIG contamination question
For those experienced tig welders on the board, does soapstone contaminate the weld when TIGGING mild steel?
For those that dont know, soap stone is used to mark along weld lines. It doesnt wipe off easily, and doesn't boil off due to the heat generated while welding.
Thanks
Old Oct 14, 2004 | 02:16 PM
Doctor CorteZ's Avatar
Default Re: TIG contamination question (juicedse)
I prefer as clean as possible.
cant you remove the marks ?
Old Oct 15, 2004 | 07:01 AM
juicedse's Avatar
Default Re: TIG contamination question (Doctor CorteZ)
Yes I could, I was wondering if it would harm the weld any if I didnt. Like when I MIG, I follow my line made with soapstone, doesnt do anything to the weld.
Old Oct 15, 2004 | 09:31 AM
jdmlife's Avatar
Tig is a very paticular metal and very easy to mess up. for mild steel clean your metal with a stainless steel brush.. i am a AWS certified welder so let me kmow of anymore questions you have
Old Oct 15, 2004 | 09:36 AM
Default Re: TIG contamination question (jdmlife)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmlife &raquo;</TD></TR><TR><TD CLASS="quote">Tig is a very paticular metal and </TD></TR></TABLE>
Tungsten Inert gas is a very particular metal ?
I'm lost on that one.
Old Oct 15, 2004 | 09:37 AM
legendboy's Avatar
Yes soap stone will contaminate your weld. Try using thinner to remove it.
Old Oct 15, 2004 | 10:46 AM
Lamchop0000's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doctor CorteZ &raquo;</TD></TR><TR><TD CLASS="quote">
I'm lost on that one. </TD></TR></TABLE>
same here. haha
Old Oct 15, 2004 | 01:28 PM
brokeasscrix's Avatar
you can use a regular *** wire brush to clean mild steel. stainless wire brushes are traditionally used to clean aluminum.soap stone will cause porosity in the weld. the reason you dont see any contamination in wire feed is because it will constantly feed wire in the puddle so you cant see it apon visual inspection. if you where to go and xray the metal, you will see porosity within the weld itself! and if you want to clean soapstone off the base metal, just use a wire brush and wipe off the excess with a clean rag! hope this helps!
HT Chaplain
Welding / Fabrication
Jan 25, 2008 06:23 PM
silentdaredevil2
Jul 24, 2006 10:41 AM
Tigfab
Feb 8, 2006 12:56 PM
.David
Oct 26, 2004 11:28 PM
RCautoworks
Oct 5, 2004 09:20 PM
