Help! Hooking up gauges!
Old Oct 14, 2004 | 12:52 PM
4genaccordfreak's Avatar
Default Help! Hooking up gauges!
hey all... hooking up a/f and a couple other gauges in my 90 accord.. although i need an ECU Pin diagram.. i already searched and already check the "guide to basic accords" and check the ECU pin code for o2 sensor.. although i don't remember which harness clip is CLIP (C) since the pic code is C16 for OBD1...
would anyone be able to help me out with a diagram or gimme an idea which clip i should i'm looking at! and also.. which wire under the steering column is the gauge power wires hooked up to so the bulbs will come on when the headlights are turned on!... please help me out! trying to get this done DIY!...
TIA
Old Oct 14, 2004 | 02:39 PM
did some trial and error... and got all the bulbs working with the headlights.. now just need the O2 sender wire... but i need to know which clip its on.. since i already know the wire is WHITE (i think) but all three clips have white wires.. HELP ME OUT
Old Oct 14, 2004 | 05:35 PM
scrubachu's Avatar
Default Re: (4genaccordfreak)
go to the local library, thats where i found all the wiring diagrams for my 93 accord and the h22 i have. just gotta do some reading.
Old Oct 14, 2004 | 06:48 PM
AVcTcEoCrd's Avatar
Default Re: (scrubachu)
splice it in with one of the wires on ur acutal o2 sensor, thas what i did. i cant remember which wire it was though
CD8coupeSiR
Jul 31, 2006 09:29 PM
Tampa94lsteg
Oct 8, 2004 08:28 PM
speester1
Mar 29, 2003 11:05 AM
1tyme
Nov 12, 2002 05:10 PM
gsr camel
Dec 30, 2001 11:43 AM
