Window Fogging question.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ross73 »</TD></TR><TR><TD CLASS="quote">Does anyone else have a problem with a type S where the windshield gets fogged extremly fast?</TD></TR></TABLE>
Happens w/both my Hondas all the time. As with every Honda I've ever owned, you can't avoid using the AC w/the defroster...but it does speed clearing the windscreen if it's not actually icy.
the a/c typically turns on in most cars when you choose the front defogger. the a/c removes the moisture from the air since a fogged window is caused by just that...moisture.
it doesn't defrost the windhield. if it did, there would be heater element lines on it like the rear window (defroster).
