Z6 valvetrain question
Can the rocker arms and shafts on a Z6 be removed w/o disturbing the distributor or cam? Is it common to have excessive slop where the rocker arms connect to the rocker shaft? Thanks for your time.
should be able to, not too sure though. i'm thinking all you have to do is make sure you take out the top distributor bolt and unbolt the cam journals and the rocker arms come with it. any kind of sludge or goop is bad too.
B16aDasher
Mar 7, 2005 04:19 PM
simplypinoyy
May 11, 2004 01:03 PM
builthatch
Jan 24, 2004 08:21 PM
