Who use a kevlar clutch disc in their 300whp+ car ??? take a look...
Old Oct 14, 2004 | 10:14 AM
yellowturbo's Avatar
Default Who use a kevlar clutch disc in their 300whp+ car ??? take a look...
So here is my story about all my clutch I had on my D16Z6 turbo.
at 240 whp : OEM disc with a double pressure plate. This setup was the one that I prefered the most... engagement was really smooth and was holding fine... the clutch never slept BUT the disc was over after like 10 month... I can live with this...
at 287 whp: when I got my new turbo I installed a new 3 pucks un-sprung disc with the same double pressure plate... It was a bitch to drive I really disliked this setup... but I tryed to keep it.
Went to the dyno to tune with racing fuel... the disc started to slip at around 310 whp... the problem was probably the pressure plate... So I ordered a Action 2ms. Took like 1 month to get it... oh well thats another story.
at 333 whp: Still on the Action 2ms ( 6 puck with spring ) and I really dont like the feeling of this clutch...
So ... I think the best choice would be, for me who drive the car most of the time on the street ( but I love to go at the track sometimes ), a kevlar disc for his smooth engagement ( thats what I heard )
Now my questions are... who know if it will hold up over 300 whp ?? can I go to the track with this kind of disc ?? and if someone use one or tryed one... could you tell me how it was please ! I dont know why but kevlar disc are not really used by what I saw...
Thanks
Mat
Old Oct 14, 2004 | 11:32 AM
civickiller's Avatar
Default Re: Who use a kevlar clutch disc in their 300whp+ car ??? take a look... (yellowturbo)
im curious to know what clutch the 300whp guys are using
Old Oct 14, 2004 | 11:33 AM
b16hybridsol's Avatar
i have a stage 3 clutch masters in my h22 turbo teg and its held up fine, i think the pressure plate is the real issue when getting into higher hp when you are running a stage 3 or higher clutch. i say you'll be fine with the kevlar disc, but i'm not sureup to what hp, i might try mine after the rebuild (550ish whp)
Old Oct 14, 2004 | 11:36 AM
FOrSfEd's Avatar
Default Re: Who use a kevlar clutch disc in their 300whp+ car ??? take a look... (b16hybridsol)
RPS stage three clutch works wonders, holds the power, and is very smooth as far as engagement goes.
Old Oct 14, 2004 | 11:44 AM
do RPS clutch have a website ??
Old Oct 14, 2004 | 12:29 PM
so who know how much torque the 2KS could hold ???
Old Oct 14, 2004 | 12:35 PM
95GSRTT
Guest
Posts: n/a
Default Re: (yellowturbo)
rps website is turboclutch.com I would talk to marty-t i think thats his name on HT. He has got some really good deals on RPS clutchs.
Old Oct 14, 2004 | 12:45 PM
Finland's Avatar
I have 100+ drag launches on my CM stage 3, and couldn't be happier with it..great engagement, and no fade at all yet
Old Oct 14, 2004 | 12:47 PM
ATS*Mark's Avatar
OG triple OG
Default Re: (boost psycho)
i just ordered the action 2md because my act is going to ****...i hope it holds my power.
Old Oct 14, 2004 | 01:08 PM
Boltz's Avatar
Default Re: (Hella_JDM)
CM stage 4 here, hasnt taken much abuse but so far it holds all the power and I think its super easy to drive
Old Oct 15, 2004 | 04:08 AM
do you guys think that the segmented kevlar disk from CM could be a good choice for me ??
Thanks
http://www.clutchmasters.com/shop/
Old Oct 15, 2004 | 04:47 AM
ELSpool's Avatar
Default Re: (Boltz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boltz &raquo;</TD></TR><TR><TD CLASS="quote">CM stage 4 here, hasnt taken much abuse but so far it holds all the power and I think its super easy to drive</TD></TR></TABLE>
I just wore mine out. CM Stage 4 lasted 15,000km and about 20 passes at the track this year. Was very easy to drive and did hold well until now. I would have thought it would have lasted longer though.
Old Oct 15, 2004 | 04:54 AM
Default Re: (ELSpool)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ELSpool &raquo;</TD></TR><TR><TD CLASS="quote">
I just wore mine out. CM Stage 4 lasted 15,000km and about 20 passes at the track this year. Was very easy to drive and did hold well until now. I would have thought it would have lasted longer though. </TD></TR></TABLE>
thats why im maybe looking for a segmented kevlar disk... really smooth engagement a longer life too... but I need more opinions about it on ...
Old Oct 15, 2004 | 06:50 AM
drumking15's Avatar
i used to run the same kevlar disc...its great for the street but i was just sotck w/ a few upgrades....it tends to slip when it gets hot...but it takes a lot...about 6 track runs to be exact...after that it took a while to cool down...but still grabbed easy...great for the street!
Old Oct 15, 2004 | 07:03 AM
Default Re: (drumking15)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drumking15 &raquo;</TD></TR><TR><TD CLASS="quote">i used to run the same kevlar disc...its great for the street but i was just sotck w/ a few upgrades....it tends to slip when it gets hot...but it takes a lot...about 6 track runs to be exact...after that it took a while to cool down...but still grabbed easy...great for the street!</TD></TR></TABLE>
thanks... yeah I heard tht they dont like the heat that much
I just emailed CM to really know if it would hold my race setup at 335whp ?? I begin to think that it wont...
Old Oct 15, 2004 | 07:41 AM
salt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellowturbo &raquo;</TD></TR><TR><TD CLASS="quote">so who know how much torque the 2KS could hold ??? </TD></TR></TABLE>
I have a 2KD with a 1.8 with SC61 turbo about 10psi. running best time of 12.4 @ 119
I have had no slipping issues at all. I have had this clutch about 2 years, but only about 10k miles on it. I had the tranny out about 1000 miles ago and the clutch still looked brand new, as well as the pressureplate and flywheel. The only thing I was told about is to not do too many hot passes on it. I did 3 rounds in a row with no cool down in bracket racing and it was fine. I am going start street course racing next year, but that dosent seem as brutal, but we will see.
Old Oct 15, 2004 | 07:52 AM
Civic TSI's Avatar
Guys, keep it mind that this is for a D16 so whenever you say that it works and hooks well on your B or F doesn't matter.
I've been runnning a CM4 for more than 5 years now. It's kind of a bitch, but it hooks well. I've rebuild the disc 3 times, the first two were done very closely but I guess I had my flywheel properly surfaced the last time cuz it has been more than 3 years and it's still on the car. Agreed I don't drive the car a lot but still...
I might check for something else for next year, I might need something more "aggresive"
Old Oct 15, 2004 | 07:59 AM
Default Re: (Civic TSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic TSI &raquo;</TD></TR><TR><TD CLASS="quote">Guys, keep it mind that this is for a D16 so whenever you say that it works and hooks well on your B or F doesn't matter.
I might check for something else for next year, I might need something more "aggresive" </TD></TR></TABLE>
well I think that 300whp+ on a B, D, H X loll is all the same... the clutch is maybe not exactly the same but it give me a good idea....
Old Oct 15, 2004 | 09:45 AM
Junglesnake's Avatar
I have a friend with a Spec Stage 3 on his D and he really likes it, as the engagement is smooth and the pedal has an almost stock feel.
Old Oct 15, 2004 | 10:30 AM
how much whp his car have ??
Old Oct 15, 2004 | 10:35 AM
Civic TSI's Avatar
You might want to ask "How much Tq does he have" instead of whp
Old Oct 15, 2004 | 10:42 AM
yeah I didnt think about it but it gives me a good start.
Old Oct 15, 2004 | 11:34 AM
whackassfawker's Avatar
cm3 for me 345whp. 50+launches.10,000km
Old Oct 15, 2004 | 11:36 AM
thanks dude thats what Im looking for !
Old Oct 15, 2004 | 11:48 AM
boostd hatch's Avatar
I have had a RPS clutch in my car for 5 boosted years and it has finally let go, but it took 25 inch slicks to kill it, also it is great for daily driving very smooth engagment with quite a bit of holding power. I am right around 330 whp also, hope that helps.
