Auto into 5 speed?
Old Oct 14, 2004 | 08:07 AM
HatchbackSqueegee's Avatar
Default Auto into 5 speed?
I have a 96 Civic hatch that's Auto..... is it going to be a pain in the *** to swap B18c or h22a ect..... I know I'll have to replace the center console and tach. Anything else special?
Old Oct 14, 2004 | 08:08 AM
JDMallTHEway's Avatar
Default Re: Auto into 5 speed? (HatchbackSqueegee)
you need to add a clutch pedal
Old Oct 14, 2004 | 08:11 AM
.BigSexy's Avatar
most hood white kid
sell ur car and buy one with a manual tranny, u will need an entire pedal assembly, with the master cylinder, etc. not sure whatelse...why will u have to changethe center console?? and u dont have to have a tach, but if if u buy a c1 swap, just buy an Si cluster, with an 8200 redline
Old Oct 14, 2004 | 08:12 AM
I forgot about the clutch. Is that going to involve anything major? Like cutting a big a$$ hole.
Default Re: (egcoupe94)
ditto, but it can be done.
Old Oct 14, 2004 | 08:13 AM
.BigSexy's Avatar
most hood white kid
in my opinion, converting from auto to manual isnt worth it, especially if u are new, u probably wont be able to do it urself, just buy a manual car, but just my .02 cents
Old Oct 14, 2004 | 08:14 AM
no, I completely agree. it will porbably be cheaper to sell and rebuy anyways
Old Oct 14, 2004 | 08:16 AM
.BigSexy's Avatar
most hood white kid
yeah, but its just my opinion, maybe he likes the challenge of changing the auto to manual, i know that i wouldnt want to
Old Oct 14, 2004 | 08:17 AM
Well, I don't want to sell it I just bought it + its silver! and the body isn't like all fucked up like all the other hatches I've looked at. I've been looking for 2 months and this one had the nicest paint body and didn't look like someone had been chucking rocks at it for 5 years like all the other ones.
Old Oct 14, 2004 | 08:19 AM
stock hatches in good condition are hard to come by. you can do it, but it will take time and money. but i understand where your coming from.
Old Oct 14, 2004 | 08:23 AM
.BigSexy's Avatar
most hood white kid
go to a local shop, and ask them about converting it, if u are new, i can almost gurantee that u wont have the knowledge to do it, have u ever worked on a handa before, like swap an engine or anything like that??
Old Oct 14, 2004 | 08:34 AM
The most I've ever done was put a super charger on my 99 hatch.... I sold it thinking I was going over sea's b/c im in the Army but now I wish I didn't sell it.
I swear its imposable to find a hatch that's not all dented up and after 2 months of examining at least 100 cars all over the US I found one!!!!!!! and now everyone is saying I should just sell it and get one with stick!!!! That can't be..... if it wasn't hard enough to find a hatch at all much less one in mint. Now you guys are saying just get rid of it b/c of a peddle swap?
Old Oct 14, 2004 | 08:37 AM
.BigSexy's Avatar
most hood white kid
im just saying that is my opinion, so what u want, it will be tough, but do what u want, we are just here to help, not to tell u what to do
Old Oct 14, 2004 | 11:40 AM
SRCivic97's Avatar
It's definitely possible - and affordable if you can get some of your parts salvage and not buy everything new. Time wise it's definitely cheaper to go out and buy a new car, but if you bleed oil, auto to manual can be worth every penny. Goodluck
Old Oct 14, 2004 | 12:25 PM
Default Re: (SRCivic97)
I was figuring it would just take a little time but I would end up doing the switch when I did an engine swap. I'm still a few months out from that anyhow.
Old Oct 14, 2004 | 12:40 PM
Heylookits shawn's Avatar
Default Re: (HatchbackSqueegee)
its really not all that hard to do, just its a lot of work. you need a new pedal assembly, clutch master cylinder, cut a hole in the firewall for said master cylinder, manual tranny and clutch line/cable. also you would need a new ecu and axles.
Old Oct 14, 2004 | 01:10 PM
2fast4u831's Avatar
I'm really 2slow
i had 5 posts when I did my auto-manual conversion parts list: tranny, flywheel, clutch,clutch lines,slave cylinder+master, 5 speed starter,pedals, linkage with shifter, 5 speed ecu, auto-manual tranny mount. I think thats it. In your case you need the proper axles
Old Oct 14, 2004 | 01:18 PM
b18c1eg
Guest
Posts: n/a
Default Re: (2FAST4U831)
It's not hard at all. I did one a couple years ago. My recommendation is go to a junk yard that has a Civic with a 5 speed the same year as yours. Pull all the stuff out you need and you're on your way. I repinned my automatic harness with all the wiring I needed from the ignition switch to the engine harness. That way I had no splices. The only thing that I had to splice was the back-up lights cause they were in a completely different spot than the 5 speed model. If you are doing a swap anyway, you'll be getting most the expensive parts with it.
Grab a Helm's and go at it. Especially if you've found a hatch you really like.
Brad
PS The reason I say same year is because Honda changed some of their connections at the interior fuse box throughout the years. You should be fine sticking with a 96-98 Civic 5 speed harness. Other years may work... but why guess?
EpicKills
Apr 16, 2008 03:54 PM
rota power
18
Dec 18, 2005 10:05 PM
sojumk
Feb 25, 2004 04:53 PM
beer4me20
Dec 24, 2003 04:15 PM
