SUPER HIGH IDLE WHEN COLD! HELP!
Old Oct 14, 2004 | 07:17 AM
bluebomb's Avatar
Default SUPER HIGH IDLE WHEN COLD! HELP!
Hey,
i have an 01 integra LS in a 95 honda civic.
When the car is cold, the car idle's very high, around 4k-4500RPM....once its warm, it idle's nice (around 800-900RPM)...what would cause this, and how do i fix this?
Letme know
Johan
Old Oct 14, 2004 | 07:29 AM
Phatch99's Avatar
Default Re: SUPER HIGH IDLE WHEN COLD! HELP! (bluebomb)
might be idle air control (iac)??
Old Oct 14, 2004 | 07:48 AM
mmuller's Avatar
Mad Scientist
its your fitv, take it out and apart; screw in the little white piece in.
Old Oct 28, 2004 | 06:58 PM
civiceg9's Avatar
Default Re: SUPER HIGH IDLE WHEN COLD! HELP! (mmuller)
I have the same problem in with my Si EG
when cold it runs to 3000rpm
once warm is ok
where is the fitv?
Old Oct 28, 2004 | 07:21 PM
eg6T's Avatar
Default Re: SUPER HIGH IDLE WHEN COLD! HELP! (civiceg9)
when the engine is cold,the rpms are suppose to go higher when it starts,but no 4000,****...but if the idle jumps around when it is warm,then your fast idle valve is defected,but look into your fitv...like the dude said above,screw it in
Old Oct 28, 2004 | 07:35 PM
PrettyLude's Avatar
fitv is right below the throttle body with coolant lines running to it
Old Oct 29, 2004 | 02:01 AM
Alstare's Avatar
Default Re: (PrettyLude)
Yeah definitly the FOV take it apart and screw it back in and you'll be set, mine just ided and was giving me a damn headache till i found it...
Old Oct 29, 2004 | 04:20 AM
EE_Chris's Avatar
It does not appear that a FITV exists on an '01 LS - can someone confirm that there is indeed a FITV present and that this picture is wrong (otherwise, don't bother looking for it, is all I'm getting at)?
Old Oct 29, 2004 | 05:45 AM
JimBlake's Avatar
Default Re: SUPER HIGH IDLE WHEN COLD! HELP! (EE_Chris)
Yeah, I don't know what year they did that. Maybe beginning with OBD-2? The function of the FITV is incorporated into the AICV.
AICV is # 11, so take it off & clean it. Does the newer AICV have stuff inside that comes loose? Maybe it's bad, so cleaning might not help?
Set base idle speed. IF it's the same as my '95, here's how...
Warm up the engine completely. Unplug the wiring from the AICV & use the throttle so it doesn't stall. Carefully release the throttle, the idle will be low. Use the little screw #1 to adjust idle to 450. (Use a good tach, 'cause the one in the cluster might not be very accurate down there.) When you plug the AICV back in, the idle should go up where it belongs.
Old Oct 29, 2004 | 09:24 AM
CivicHatchback14's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">its your fitv, take it out and apart; screw in the little white piece in.</TD></TR></TABLE>
What he said! I did it on my LS and it worked great. My idle was around 3400 at cold idle, and now it is right around 1200.
Old Oct 29, 2004 | 10:28 AM
mmuller's Avatar
Mad Scientist
Default Re: SUPER HIGH IDLE WHEN COLD! HELP! (CivicHatchback14)
but yeah, obd2 cars dont have fitv, at lest b-series; pretty sure its the same for the rest.
read the thread wrond..duhh
Old Oct 29, 2004 | 11:17 PM
civiceg9's Avatar
how u turn the screw on the IACV
seems like u need a key to turn it. (only have five corners the damn screw)
Old Oct 30, 2004 | 04:07 AM
honda_power69's Avatar
Hmm might be time for me to find a donor OBD2 car and do a "FITV" tech article on it as well...
stuckinmud
Aug 14, 2009 08:32 AM
Professor Gascan
Aug 7, 2009 07:26 AM
VtecbOi
Mar 15, 2004 09:49 PM
crashtest Sonny
13
Mar 4, 2003 03:49 PM
