NepTune in control
Old Oct 13, 2004 | 11:02 PM
prelude994e's Avatar
Default NepTune in control
just curious if anyone here has had any experience/success running the new Neptune software on turbo applications.....
In less then two weeks my built turbo lude will be controlled by this NepTune, ill let everyone know how it goes, but just curious to hear any stories, advice, feelings, etc?
Old Oct 13, 2004 | 11:03 PM
PrecisionH23a's Avatar
Default Re: NepTune in control (prelude994e)
here we go again...
Old Oct 13, 2004 | 11:49 PM
flip1199's Avatar
Default Re: NepTune in control (PrecisionH23a)
how far away is your neptune tuner/dealer?
Old Oct 14, 2004 | 08:38 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">here we go again...</TD></TR></TABLE>i did a search bro...................<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flip1199 &raquo;</TD></TR><TR><TD CLASS="quote">how far away is your neptune tuner/dealer?</TD></TR></TABLE>......and its only 1 hour away from me
Old Oct 14, 2004 | 08:41 AM
Elkins911's Avatar
never heard of them. then again im n/a
Old Oct 14, 2004 | 09:53 AM
ChrisRicketts's Avatar
Default Re: NepTune in control (Elkins911)
i've never heard of the NepTune either. I'd stick to Hondata since it's easy and lots of people can tune it. I wish i would have used Hondata, but i went AEM instead. I have some problems at idle because of it.
I'll be interested to see the results though, is this a new system? how much was it?
Old Oct 14, 2004 | 12:16 PM
alphajesse's Avatar
I have a P13 (stock 4th gen VTEC ECU) tuned with NepTune.
I have FTL, and some other good stuff.
NepTune supports boost on a p13, and it is some good stuff.
If the tuner you use knows what he is doing, there is nothing wrong with being unable to change the maps yourself.
With a quality tune, the sensors in the ECU can account for elevation, weather and temperature no problem.
So far, with the shops that have access to NepTune, there isn't anyway you can go wrong. No dopes have access to this tuning solution.
Also, if you have an OBD1 4th gen, you will save all sorts of money versus hondata!
1. You already have the ECU.
2. Chipping a p13 is easier than a p72/p28
3. NepTune is only ~$100 + tuning! (Check with Jeff for actual prices)
Advantages over hondata:
You can control everything properly, even EGR if you desire.
The VSS enrichment maps match the gearing in your car.
Better customer support.
The p13 knock board will work properly with a h22.
Old Oct 14, 2004 | 12:21 PM
Default Re: (alphajesse)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alphajesse &raquo;</TD></TR><TR><TD CLASS="quote">I have a P13 (stock 4th gen VTEC ECU) tuned with NepTune.
The p13 knock board will work properly with a h22.</TD></TR></TABLE>
Wow, sounds like a good system. I was under the impression that it was an all out standalone system like the AEM or Haltech, but that alternative sounds like a pretty inexpensive way of getting things done the right way. good luck with things.
Old Oct 14, 2004 | 12:39 PM
HRTuning's Avatar
Default Re: (ChrisRicketts)
Just to clear up some confusion... The P13 Boost code is not being released... I take it you're using a different ECU?
Old Oct 14, 2004 | 01:42 PM
alphajesse's Avatar
Default Re: (HRTuning)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HRTuning &raquo;</TD></TR><TR><TD CLASS="quote">Just to clear up some confusion... The P13 Boost code is not being released... I take it you're using a different ECU?</TD></TR></TABLE>
My bad. I shouldn't have assumed that it was being released.
Old Oct 15, 2004 | 07:41 AM
you actually use a stock p28 and socket it. then the tuen shop must charge you an additional 100 bucks to use the NepTune software. Do the math, your saving lots of money.......i will keep everyone posted whos interested, my dat is october 26....take care guys, wish me luck......i have faith in jeff
Old Oct 16, 2004 | 12:25 AM
B18OnTop's Avatar
Default Re: (prelude994e)
Going neptune at the end of this month.
-Aaron
Old Oct 16, 2004 | 10:43 AM
Default Re: (B18OnTop)
good to hear, i hope to let you know how it turns out, as my date is set for 26th.......10 days...
Old Oct 20, 2004 | 06:22 AM
B-Hatchie's Avatar
I getting neptune also. Check going in the mail friday For anyone that wants to now more about it check out: neptune.evans-tuning.com good ****
Eglifestyle
Jul 12, 2006 12:16 PM
lerner
11
Apr 29, 2006 05:47 PM
southpole12
Jul 23, 2005 05:38 PM
effinnwackk
37
Apr 13, 2005 11:43 PM
boostjunkie757
Oct 9, 2004 09:55 AM
