ac compressor question on swap
Old Oct 13, 2004 | 06:55 PM
JerKeK9's Avatar
Default ac compressor question on swap
hey im about to swap an ls motor into my car, kinda a dumb question but i was wondering if the d-series ac compressor would be a ble to bolt into the ls motor, or would it not line up right thanks
Old Oct 13, 2004 | 07:38 PM
=GAME='s Avatar
Default Re: ac compressor question on swap (dx-r)
direct bolt if you have the Del Sol Vtec a/c bracket.
Old Oct 13, 2004 | 07:45 PM
Built Beast's Avatar
Default Re: ac compressor question on swap (=GAMEOVER=)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by =GAMEOVER= &raquo;</TD></TR><TR><TD CLASS="quote">direct bolt if you have the Del Sol Vtec a/c bracket.</TD></TR></TABLE>
yep, I am sure some one will post the part number for ya, if I can find it real quick I will post it for ya.
Old Oct 13, 2004 | 07:47 PM
Default Re: ac compressor question on swap (R33CIVIC)
96 del Sol AC bracket: 38930-P54-000 is the part number, that is if you are wanting to retain your A/C
Old Oct 13, 2004 | 08:33 PM
JerKeK9's Avatar
so thats all i need to use my d16y7 ac compressor and get it to bolt onto the ls motor??
Old Oct 13, 2004 | 09:36 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dx-r &raquo;</TD></TR><TR><TD CLASS="quote">so thats all i need to use my d16y7 ac compressor and get it to bolt onto the ls motor??</TD></TR></TABLE>
I just posted that you needed the bracket to be able to retain your a/c, meaning you can bolt your a/c compressor on the the bracket and motor if you get the Del Sol A/C bracket...I even included the Honda part number in case you wanted to order it from your dealership.
Old Oct 13, 2004 | 09:41 PM
JDMallTHEway's Avatar
what you can do, is just bole the compressor onto your block, only the right 2 bolt holes will line up, and get a three groove belt of the same size as teh factory d16 belt, and that will work. make sure the belt is tight, it may need to be retightened occasionally
Old Oct 14, 2004 | 06:00 PM
JerKeK9's Avatar
arite, thanks for all you guys' help
Speed94
Aug 13, 2008 03:32 PM
1 sLoW hAtCh
May 8, 2006 05:11 AM
ThE BiG RauL
Apr 14, 2006 10:14 PM
97civicsedan
May 21, 2005 07:05 PM
b18bme
May 5, 2004 10:32 AM
