Shop needs a H-T member to use car to test fit -----
We need to test fit a new header on a 92 up civic VTEC asap --
https://honda-tech.com/zerothread?id=1004567
that the header, if and when it fits we can give a special deal on the header or if the owner of the car wants a deal on dyno tuning 50% off ? of a deal on a part that you might want to pick up ? ASAP
Hey Jason...I actually need to get some work done at your shop, but if you want to use my Sol at the same time that would be cool. SOHC Vtec is what you need right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by portenio78 »</TD></TR><TR><TD CLASS="quote">Hey Jason...I actually need to get some work done at your shop, but if you want to use my Sol at the same time that would be cool. SOHC Vtec is what you need right?</TD></TR></TABLE>
we need to test fit like RIGHT NOW --- cll the shop to set it up please 909-608-7123
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RageDzine »</TD></TR><TR><TD CLASS="quote">
we need to test fit like RIGHT NOW --- cll the shop to set it up please 909-608-7123</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RageDzine »</TD></TR><TR><TD CLASS="quote">if and when it fits we can give a special deal on the header or if the owner of the car wants a deal on dyno tuning 50% off ? of a deal on a part that you might want to pick up ? ASAP </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eh6 »</TD></TR><TR><TD CLASS="quote">What's in it for the person that brings the car?</TD></TR></TABLE>
thats what we can do --- someone above said he was coming but ?????
Well I just dropped my car off at Rage so they can do what they need to do, and while its down there its getting a new water pump and timing belt. The testing will be done over the next couple of days and I guess they are even gonna throw it on the dyno to...but too bad work gots me on lock down and I will miss all the fun. Thumbs up for Jason and his crew at Rage.
Base line pass 114hp 101tq fingers crossed about to do stock manifold and the RageRacaing Header
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RageDzine »</TD></TR><TR><TD CLASS="quote">over 120 hp
post dyno sheets tom.</TD></TR></TABLE>
Wow. Nice
Good powa y00000
mad 3Rd GeAR vTeC y0000!!!
post dyno sheets tom.</TD></TR></TABLE>Wow. Nice
Good powa y00000 mad 3Rd GeAR vTeC y0000!!!
Hey Jason I hope my girl can pick up my car on Tues. cuz I am working swing shift all week. Wow over 120 huh, thats pretty strong for a basically stock single cam. That header must be the ish. JUst wondering...did you guys tweek my ignition and cam timing? The way I brought it in was ignition at 18 degrees and cam advanced 2 degrees?
the timing was set to 16 and gear to 0 for a fair stock to stock test. then we set it at 17 and 2 for your header
Here it is ------
93 DelSol Sohc Vtec - AEM cam gear - Cold Air - full exhaust - cat - 156637.o miles on the car.
Run oo2 is car tuned with another header
Run oo1 is base run stock manifold
Run oo6 is with Rage Racing Header
jadugartir
20
May 15, 2007 02:08 PM
......wutup y0??? i'm down for the crown
