bearing questions! already did a search
Old Oct 13, 2004 | 06:12 PM
Trailz-EX's Avatar
Default bearing questions! already did a search
i have a d16y8 and recently put about 4 big holes in the block via a connecting rod..
anywho i had another d16y8 block and crank and all that stuff, but it needs a rebuild.
looking at the crank i see these letters and numbers: (starting from the timing belt side going to the flywheel side of the crank.) B 3 C 2 C 3 B 3
timing ---=|___|---|__|---|__|---|__|---( Fly
from what i think is right i need:
1- pink main
1- pink rod
3- green main
1- green rod
1- brown main
2- brown rod
yes.. no.. maybe... stop trying to build engines! let me know
Old Oct 13, 2004 | 06:29 PM
IN VTEC's Avatar
Default Re: bearing questions! already did a search (Trailz-EX)
What are the letters on the block's skirt?
Old Oct 13, 2004 | 07:01 PM
Trailz-EX's Avatar
Default Re: bearing questions! already did a search (IN VTEC)
couldnt find any... the only lettering i saw was p2e, but i see that casted into a ton of other parts on the motor so i dont think that it... were would they be that i dont have them... we miked the crank all the main bearing journals are within .003in. of eachother 2.166 - 2.165
Old Oct 13, 2004 | 07:04 PM
Trailz-EX's Avatar
also i checked for the color on the bearingss only a few had a color on them the ones that did the color looked faded like a tan color i dont trust that..... i want o do this right not guess
Old Oct 13, 2004 | 07:08 PM
IN VTEC's Avatar
It's possible that they're not stamped into the block skirt. My block never had them.
I'd just mic everything to spec. The number/letter coding can be off.
Old Oct 13, 2004 | 07:21 PM
Trailz-EX's Avatar
they dont wanna hear mic specs when you order them... makes them have to do more work, they want a color so they can be lazy i guess ....what a pain in da butt... THANKS!
Old Oct 13, 2004 | 07:40 PM
IN VTEC's Avatar
Measure the ones you have. You can get at least ballpark with that.
GsrIntegra789
Jan 26, 2010 08:21 AM
GSR-C5
Jul 1, 2007 05:28 PM
SkRiBLaH
Jul 28, 2004 10:24 AM
hksbigboi4
Apr 16, 2004 07:48 AM
