Bad Rod Bearing reason for no oil pressure?
Old Oct 13, 2004 | 06:08 PM
DjDrift's Avatar
Default Bad Rod Bearing reason for no oil pressure?
Well I have a h22a4 that I have diagnosed with a bad rod bearing not completely spun there is alot of play though. Before pulling off the oil pan to inspect I tried to read oil pressure by just cranking the motor with no spark plugs battery was almost dead and I got 0 psi. Just wondering if I should be getting a reading with a bad rod bearing and dying battery?
Old Oct 13, 2004 | 06:30 PM
mmuller's Avatar
Mad Scientist
Default Re: Bad Rod Bearing reason for no oil pressure? (DjDrift)
yeah they would cause low oil pressure; but you wont get much pressure by cranking anyways.
defenetely more than 0 though
Old Oct 14, 2004 | 03:40 AM
civic-4-ges's Avatar
Default Re: Bad Rod Bearing reason for no oil pressure? (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">but you wont get much pressure by cranking anyways.
Definately more than 0, but not much more than say 10
Old Oct 14, 2004 | 07:15 AM
mmuller's Avatar
Mad Scientist
Default Re: Bad Rod Bearing reason for no oil pressure? (civic-4-ges)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic-4-ges &raquo;</TD></TR><TR><TD CLASS="quote">
Definately more than 0, but not much more than say 10</TD></TR></TABLE>
yep, cranking pressure goes up to about 15/18 psi
Old Oct 14, 2004 | 07:48 AM
H22coupe's Avatar
yep, cranking pressure goes up to about 15/18 psi</TD></TR></TABLE>
Slow crank due to dying battery is gonna drop pressure even more too
Old Oct 14, 2004 | 02:56 PM
DjDrift's Avatar
Default Re: Bad Rod Bearing reason for no oil pressure? (H22coupe)
Thats what im thinking so im going to replace the bearing charge the battery and see if I get pressure I dont want to replace the oil pump if I dont have to. Thanks for the responses.
Old Oct 14, 2004 | 04:24 PM
bruthaboost's Avatar
No, a bad rod bearing will not affect oil pressure. It's not any where along the oil pressure "path."
Old Oct 14, 2004 | 05:59 PM
Default Re: Bad Rod Bearing reason for no oil pressure? (bruthaboost)
It will affect pressure, just not greatly. The bearings are designed to basically "Leak" oil. They of course are intended for a certain amount of difference between crank diameter and bearing bore size. Any larger amount will result in a pressure loss. The greater the difference, the greater the loss.
Measurable?? That really depends on the condition of them
Old Oct 14, 2004 | 06:05 PM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bruthaboost &raquo;</TD></TR><TR><TD CLASS="quote">No, a bad rod bearing will not affect oil pressure. It's not any where along the oil pressure "path." </TD></TR></TABLE>
mmm, yes it will and yeah thats an oil ''path''
Old Oct 14, 2004 | 06:39 PM
Explain to me exactly how Oil pressure flows to a ROD bearing. Not a main (he didn't mention mains).
As far as I know, oil leaves the pump through the galley to the filter, back from the filter to the return galley and that galley has direct feeds to the oil sender, mains, and cylinder head. Have you pressure tested a block before? I have. Trust me, you don't need the connecting rods on to do it. Somehow, I don't see oil pressure feeding the rod journals considering there is no oil path through the crank to those journals. I guess I'm missing something. Someone help me out.
jeff
Old Oct 14, 2004 | 07:26 PM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bruthaboost &raquo;</TD></TR><TR><TD CLASS="quote">Explain to me exactly how Oil pressure flows to a ROD bearing. Not a main (he didn't mention mains).
jeff</TD></TR></TABLE>
what do you think feeds the rod bearings with oil? do you think oil just splashes in there?
went and took a pic:
Old Oct 14, 2004 | 07:35 PM
Muckman's Avatar
Moderator in Chief
Dude you must have never seen a crank in person. Theres oil paths drilled through both ends of the crank.
Just like if you have a crank/rod bearing with way too much clearance it will cause lower oil pressure. The same could be true for a spun bearing.
jiggacivic
Apr 9, 2007 05:02 PM
Fo-Do Fanatic
14
Jan 15, 2007 06:33 PM
ricefarmer
Jan 20, 2005 05:59 PM
pissedoffsol
Sep 24, 2004 12:08 PM
toooslow
Oct 15, 2003 10:47 AM
