serial number on block
Old Dec 16, 2001 | 06:33 PM
MGD's Avatar
MGD
Default serial number on block
for example:
B16A
06403076-
is the number above, the vehicle tag
can this number verify if the motor is stolen,if i brang this number to the department of motor vehicles could they tell me any history on this motor. THANKS
[Modified by A42NV, 3:35 AM 12/17/2001]
[Modified by A42NV, 3:36 AM 12/17/2001]
[Modified by A42NV, 3:37 AM 12/17/2001]
[Modified by A42NV, 3:38 AM 12/17/2001]
Old Dec 16, 2001 | 08:48 PM
martini's Avatar
Default Re: serial number on block (A42NV)
no, you'd have to bring the motor to them (The police station, actually) to verify the number. And if it IS a stolen engine, they will confiscate it from you right then and there.
Someone please correct me if I'm wrong.
Old Dec 17, 2001 | 06:39 AM
MGD's Avatar
MGD
ttt
Old Dec 17, 2001 | 02:05 PM
jeff652's Avatar
Default Re: serial number on block (martini)
wrong.
You can call them, at least in CA you can. The Serial number they will need will be B18C5712345
Just like you said.
HTH
Jeff
Old Jan 9, 2002 | 07:14 PM
1's Avatar
Default Re: serial number on block (jeff652)
wrong.
Just like you said.
HTH
Jeff
Who did you call? Do you know this for a fact? Was it the CHP?
Old Sep 8, 2003 | 06:59 AM
jeff652's Avatar
Wow old thread.
For clarification, you can call the CHP auto theft division office in Oakland CA with the engine serial # and they can track it to see if there are any 'events' recorded against that block.
That's how you/they find out if it is stolen or not.
No I don't have the phone #, sorry.
Jeff
Old Sep 8, 2003 | 07:48 AM
irev210's Avatar
I know block serial #'s the first # is the series, the 2nd # is usually what year it was in production, in some cases
For instance, the B16 block.
10XXXXX was made in 89
11XXXXX was made in 90
12XXXXX was made in 91
13XXXXX was made in 92
14XXXXX was made in 93
Tho that isnt always the case, ive seen 14's made in 92 etc..
same thing with 5 series block which went into civc
Also, my friends type R is # 365
his block # is 364 (because they start with block 0000
a good way to check to see if is the original motor
Old Sep 8, 2003 | 08:28 AM
plan B.'s Avatar
i thought the first number was the the generation it was from
for example a b18c1 block number : 1xxxxxx is first generation meaning its from a 94.
this is why if you buy a shortblock from the dealer it starts with 0
correct me if im wrong
Old Apr 14, 2004 | 06:48 AM
sol2nr's Avatar
Default Re: (96hatchback)
bringing this back.....
i want to know about two engines (blocks) b16a1037039 and b16a1500501.
how can i tell just from the serial code on the block which generation it is?
Old Apr 14, 2004 | 10:28 AM
SYD's Avatar
SYD
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
Default Re: (sol2nr)
Old Apr 14, 2004 | 10:58 AM
MightyMouseTech's Avatar
Default Re: serial number on block (MGD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MGD &raquo;</TD></TR><TR><TD CLASS="quote">for example:
B16A
06403076-
is the number above, the vehicle tag</TD></TR></TABLE>
Well, considering this engine is NOT from North America, I don't think the police will be able to tell you anything....
Unless this was just an example of course....
Dec 8, 2001 05:46 PM
NWPNOMORE
Dec 7, 2001 05:14 AM
