HKS Exhaust help (Bumper is melting)
Ok, i have a 00 SI and i just installed a HKS Hipower exhaust the I bought off of JDEMONE. He says the exhaust should hang a little, but my exhaust is held up really high and now my bumper is melting a LOT. How can I fix this?
I would get a muffler shop to reweld my hangers...so the bumper doesnt sit so high.
If you dont wanna do that..they make those ugly *** metal plates you bolt to your bumper.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Built2Spill »</TD></TR><TR><TD CLASS="quote">I would get a muffler shop to reweld my hangers...so the bumper doesnt sit so high.
Definately try the hangers
</TD></TR></TABLE>Definately try the hangers
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jeffk182 »</TD></TR><TR><TD CLASS="quote">Is there a way to stretch the exhaust bushings?</TD></TR></TABLE>
I seriously doubt it....those bushings arent meant to be stretched anyways.
It shouldnt cost more than $20 to get your exhaust rehung...
I had the same problem with that exhaust on my car. I just went to autozone and got some different exhaust bushings that were longer. I got two but I ended up only using one. I can't remeber if it was the right or the left one, but it made it fit just right.
That's what I did when my N1 was melting my rear bumper. You insert something inside the bushings to extend it, and hold that object in with zip-ties. Worked great for me for the 2 years I had it like that. No problems at all, and nothing's wrong with the hangers now that they're back to normal.
Ok, I bought the longer Exhaust rubber hangers from autozone (2.99 each) and I put them on. Now my exhaust hangs a lot lower so thats good cuz my bumper won't melt, but the holes on the bushing are a little big for the hangers and stuff...what should I do?
clamp something around the part of the hanger that sticks through the rubber part. I dunno. A hose clamp, 2 flat pieces of metal with a hole on each end with a bolt through each one to clamp it down. Use your imagination.
You might want to check and see if everything is sitting right in the center of the car too. If the exhaust hangs to low before to axle it could force the entire axleback up. I'm not sure if you have a hanger here, but check right in front of the rear axle, I did not have a hanger there and had to weld one in order to make my exhaust sit right.
Homericaeast
Jan 2, 2003 10:28 PM
blktyper2001
Nov 5, 2001 07:53 PM
