i wonder how these would look on a dc2R....???
Old Dec 16, 2001 | 05:38 PM
jet's Avatar
jet
New User
Default i wonder how these would look on a dc2R....???
http://cgi.ebay.com/ebaymotors/aw-cg...99291500anyone got any pics?
Old Dec 16, 2001 | 05:39 PM
Rguy's Avatar
Voted Best Looking GDD Poster
25 Year Member
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: i wonder how these would look on a dc2R....??? (jet-01)
very nice, id buy them if i had the dough.
Old Dec 16, 2001 | 05:46 PM
Hybrid ctr's Avatar
Default Re: i wonder how these would look on a dc2R....??? (Rguy)
Old Dec 16, 2001 | 05:54 PM
jet's Avatar
jet
New User
Default Re: i wonder how these would look on a dc2R....??? (Hybrid ctr)
anyone got the time to photoshop???i haven't seen one pic yet, anywhere..
Old Dec 16, 2001 | 05:59 PM
TypeR 599's Avatar
damn those rims look sweet!!!!!!!!!soo expensive..
Old Dec 16, 2001 | 06:00 PM
machgo5go's Avatar
Maybe one heavy steam roller!
Old Dec 16, 2001 | 06:19 PM
Flux's Avatar
Default Re: i wonder how these would look on a dc2R....??? (machgo5go)
I'd buy them just for the "Advance" tires...
Old Dec 16, 2001 | 06:21 PM
gamby's Avatar
Default Re: i wonder how these would look on a dc2R....??? (Flux)
That would be pimp to the Nth degree...
Old Dec 16, 2001 | 07:01 PM
RagingAngel's Avatar
Default Re: i wonder how these would look on a dc2R....??? (gamby)
I'd probably not run them.....only because I believe 16s are the biggest that should ever appear on EG/DCs.....
but thas juss me.....
Old Dec 16, 2001 | 07:10 PM
Unlimited's Avatar
New User
Default Re: i wonder how these would look on a dc2R....??? (RagingAngel)
what IF 17" were lighter?
not exactly these wheels but say 17" MF10 that weighs 15 lbs vs 15" Stock that weighs 15.5 lbs
Old Dec 16, 2001 | 08:10 PM
Mike M's Avatar
Founding Member
Works Emotion MMMMM 16" would look nicer though. 17" wouldnt have much sidewall on a DC2
Old Dec 16, 2001 | 08:42 PM
Default Re: i wonder how these would look on a dc2R....??? (Unlimited)
I'd still choose the 15s.....
people forget that it's still gonna take more energy to spin a 17 even if it is light because all the weight is gonna be at the ends of the wheels...in the form of THE TIRES....
go 15s go!!
Old Dec 16, 2001 | 08:55 PM
RyanR's Avatar
Um yeah. What has lower profile tires, 15" or 17". On a 17" you'd have less weight from the tires on the outside.
Old Dec 16, 2001 | 09:07 PM
Unlimited's Avatar
New User
Default Re: i wonder how these would look on a dc2R....??? (97TypeR_9)
sweet lets get a big debate goin
Old Dec 16, 2001 | 09:17 PM
RyanR's Avatar
Well it's just common sense. Less rubber=lighter tire.
Old Dec 17, 2001 | 05:24 AM
Brian's Avatar
I dig those rims
Old Dec 17, 2001 | 05:28 AM
Dr Pooface's Avatar
17's are useually wider than 15's. More of the mass of the wheel is farther from the center as well (spokes aren't the whole wheel).
Old Dec 17, 2001 | 07:16 AM
RyanR's Avatar
Default Re: i wonder how these would look on a dc2R....??? (Dr Pooface)
Yes but when your dealing with light weight rims such as Spoon, Desmond or Mugen, the rims are usually lighter than the tires. So I'd rather have as much rim and as little tire as possible. And the tires on those rims are 215's. That's not much larger than a 205. I would think the low profile would more than make up for the added 10mm width.
Old Dec 17, 2001 | 07:30 AM
b00st-0wnz's Avatar
From: Drinking Beer in sunny FL and jamming to Skid Row, USA
But the large mass of the wheel is further from the hub, increasing the wheels resistance to turn (lack of leverage compared to 15").
Old Dec 17, 2001 | 07:37 AM
RyanR's Avatar
Default Re: i wonder how these would look on a dc2R....??? (Dave-ROR)
Yes, but as long as you keep the same overall diameter this isn't a problem.
Old Dec 17, 2001 | 07:50 AM
Piston Honda's Avatar
The further away the mass is from the center of rotation, the more torque is needed to spin the wheel to a desired rotational speed. This is simple physics. Two identical style/made wheels of size 17" and 15" will have two different moment of inertias.
Try holding a baseball bat and hold it by the extreme end and swing it up and down. Then choke up on the bat and repeat. Which takes less effort?
Mike M's Avatar
Founding Member
It is still a problem because the 17" rim with tire although same overall diameter as the 15" with tire. The 17" Has its weight further out so it takes more to spin it compared to having the majority of the weight closer to the inner part of the rim.
Old Dec 17, 2001 | 08:07 AM
RyanR's Avatar
Default Re: i wonder how these would look on a dc2R....??? (TypeRmsm)
I understand that the further out the weight is, the more torque needed to spin it. But what I'm trying to get at is that there is less mass from the tire on the far outside. Plus there is more rim on the far outside of the rim/tire combo. Since racing rims are lighter than tires, this would be a good thing. So if you keep the same overall diameter you end up with less weight on the outside. Haven't you guys ever felt the weight of a rim before and after the tire was mounted?
Old Dec 17, 2001 | 03:24 PM
I've felt the difference in weight yes.....
from mounting a set of Spoon's with 32Rs and having them mounted with a set of Toyo TIPlus (ol' skool)
the difference is quite pronounced.
Either way, the choice is up to you....but just for the sake of argument...lightweight tires can be had in 15s.... stuff like the Hoosiers... or even conventional street tires.... ala the ones I mentioned above.
Who was it that use to run that Prelude shop that got shut down hardcore - for scamming
-when he did a dyno test between some 18in ADVANs vs the stock wheels ....and he lost some whp down low but managed to turn the same peak WHP?
Old Dec 17, 2001 | 03:57 PM
Black SVT's Avatar
iRSX-S
Aug 23, 2006 12:24 AM
tygsr
Jan 26, 2004 04:54 PM
InfamousDC2FI
Mar 31, 2003 01:02 PM
vteckiller
Dec 30, 2002 12:59 AM
mrlegoman
20
May 18, 2002 10:37 AM
