How tight? Front strut bar
Old Dec 16, 2001 | 05:03 PM
sol-man's Avatar
Default How tight? Front strut bar
I have a 95 del Sol Si and I am installing a front upper strut bar and wanted to know how many pounds to torque the nuts.
Thanks in advance.
Old Dec 16, 2001 | 10:40 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: How tight? Front strut bar (sol-man)
if using a neuspeed style bar that mounts to the upper arm assembly, 47 lb-ft.
Old Dec 17, 2001 | 03:02 PM
sol-man's Avatar
Default Re: How tight? Front strut bar (Mista Bone)
What about something like a DC sports one?
Thanks
Old Dec 17, 2001 | 10:56 PM
Mista Bone's Avatar
D Tranny Guru
What do the instructions say?
I think the DC mounts to the upper shock bolts.......
36 lb-ft
Old Dec 18, 2001 | 12:38 PM
sol-man's Avatar
The bar I got didnt come with instructions.
I got it from http://www.rojaengineering.com
Very nice looking bar
Old Dec 18, 2001 | 12:44 PM
WAFFLES's Avatar
"torque the nuts"
Old Dec 19, 2001 | 10:03 PM
WaterDrake's Avatar
New User
Default Re: How tight? Front strut bar (WAFFLES)
i'm curious as to why certain torque on the nuts would make any difference at all. If you get it to where they are tight enough to where it doesn't move, wouldn't that be good enough. I just don't see how that would make a difference since once you get it on it makes the body flex less. how would it change anything if the nuts holding it on were to be tighter?
Old Dec 19, 2001 | 10:55 PM
Calavera's Avatar
Default Re: How tight? Front strut bar (WaterDrake)
Dang, I didn't even know there was a certain amount set. I thought it was pretty much bolt on as tight as you can.
Old Dec 20, 2001 | 12:14 AM
speedymon's Avatar
Default Re: How tight? Front strut bar (Calavera)
Aigh!! silly newbies. Different bolts have different torque specs because they do different jobs. A strut bar isn't subject to the same stresses (vibration, heat...)as a lca bolt, or a wheel lug nut. Also some of the threads they attach to are softer or harder. If you torque too much you will strip it, less and it will come loose. Put 250 ft/lbs of torque on you spark plugs and see what happens. Put 1 lbs/ft on it and you will have fun. hope that helps.....I'm going to sleep.
[Modified by speedymon, 4:16 AM 12/20/2001]
Old Dec 20, 2001 | 12:56 AM
B18C-EJ1
Guest
Posts: n/a
Default Re: How tight? Front strut bar (speedymon)
Oh, do I feel for those who don't know.
I wish everyone would read about the neuspeed bar.
Here, I'll help to educate you a bit..........
Old Dec 20, 2001 | 06:09 AM
Grimm's Avatar
Default Re: How tight? Front strut bar (B18C-EJ1)
i'd say tighten the bolts to the torque they were set at, look at a manual for your car for the exact torque.
also jack your car up so your struts / shocks are extended when you install the bar, this way you are maximizing the performance your bar will give.
Old Dec 20, 2001 | 07:43 AM
speedymon's Avatar
I'm about to get that bar. Paid like 50 bucks.
racekar711
Suspension & Brakes
Nov 30, 2005 12:57 PM
spoolude
Sep 18, 2004 11:53 AM
B18CYAAA
Dec 29, 2003 12:34 AM
Vinny Chase
May 18, 2003 07:41 PM
revhrdls
Aug 4, 2001 03:51 AM
