Pic/Diagram request. Coolant lines T to the turbo
Old Oct 13, 2004 | 10:15 AM
sPaRk'iT's Avatar
Default Pic/Diagram request. Coolant lines T to the turbo
My turbo is water and oil cooled, im not sure how to connect the hose from the turbo to the coolant line, does it matter where i "T" it??
Old Oct 13, 2004 | 09:15 PM
sPaRk'iT's Avatar
Default Re: Pic/Diagram request. Coolant lines T to the turbo (sPaRk'iT)
TTT
Old Oct 14, 2004 | 03:09 PM
sPaRk'iT's Avatar
I guess noone knows either
Old Oct 14, 2004 | 03:31 PM
IN VTEC's Avatar
Remove the IACV coolant line and use the nipple from the main water pipe to feed the turbo. This will circumvent all of the throttle body and IACV coolant lines.
If you opt to not circumvent those lines, then you can tee off of the PCV purge heater line.
Tap a NPT to 1/4" or 5/16" barbed fitting into the upper radiator hose housing.
I'd be able to help you more if you told me if it was an OBD-1 or OBD-2 motor.
Old Oct 14, 2004 | 04:13 PM
sleeping GIANT's Avatar
mine is a sohc and I did as (in vtec) said in a way.
-run your turbo feed line from the return of the iacv to the turbo.
-run it from the turbo to the water pipe on the back of the block.
-Ill see if I can get some pics to work!
Old Oct 14, 2004 | 05:49 PM
djwest24's Avatar
Default Re: Pic/Diagram request. Coolant lines T to the turbo (sleeping GIANT)
find the circled nipple on your water pump connecting pipe. take off the hose, and run your feed from the end of the hose on the intake mani. and route ur return line back to the nipple.
Old Oct 16, 2004 | 05:06 PM
sPaRk'iT's Avatar
Default Re: Pic/Diagram request. Coolant lines T to the turbo (quicksilver17981)
thanks guys, anymore ways?
h23vtec_dc2
Feb 28, 2010 04:47 PM
PINKS
Feb 22, 2007 03:51 PM
Krayzielix
Jun 17, 2004 03:42 AM
airwalk07143
Jan 1, 2004 08:36 AM
Accord94DX
Apr 27, 2003 12:31 PM
