best cam for me to run?
Old Oct 13, 2004 | 09:28 AM
96tegls's Avatar
Default best cam for me to run?
i have an ls vtec. the block is a b18b1 and has new bearings but ls rods, arp bolts, and itr pistons.
the head is pr3 b16 ported to stock type r spec, milled .030.
Now my question is i would like to be able to run mean cams but i dont know if it will have high enough compression for like sk2 stage 2s. i have been searching but not finding what i need if anyone could help me and give some suggestions for cams that will work out, thanks
Old Oct 13, 2004 | 09:42 AM
smart monkey's Avatar
Default Re: best cam for me to run? (96tegls)
I would use the buddy clubs.
Old Oct 13, 2004 | 10:34 AM
98itr0448's Avatar
Your compression should be a little over 11:1:1 not counting the head being milled. Sk2 says that anything over 11:1:1 is fine for the stage II cams. I'd say this would hold true for most any stage II cam, buddyclub, toda, ect. You could run a mugen head gasket and pick up a little compression as long as clearances are all ok. Check out c-speed.com's compression calculator to figure out where your at. Good luck, don't forget upgraded valve springs with a stage II cam choice!
Old Oct 13, 2004 | 03:42 PM
96tegls's Avatar
thanks and is sk2 the best stage two to choose because i seen how bad buddy club beat the sk2 stage III
Old Oct 13, 2004 | 03:49 PM
siR cr-x's Avatar
Default Re: (96tegls)
i seen alot of people with your set up use s2s2 the BC cams are real good cams also, so whatever one you get will make good power
Old Oct 13, 2004 | 05:35 PM
eg_type_r93's Avatar
Default Re: (siR cr-x)
toda b jun2
Old Oct 13, 2004 | 06:04 PM
rcurry14's Avatar
i wouldnt want to run anything bigger than a toda a on a street motor. They are more for race motors that will get tore down every 15000 miles.
Old Oct 13, 2004 | 06:57 PM
96tegls's Avatar
yea i wish i could run jun IIIs my friend has them on his type r and its mean.
how do jun IIs compare?
Modified by 96tegls at 8:10 PM 10/13/2004
Old Oct 14, 2004 | 09:18 AM
96tegls's Avatar
anyone know how the jun IIs compare to jun IIIs
Old Oct 15, 2004 | 02:44 PM
96tegls's Avatar
i also have one more question. i want to give it some nitrous how safe am i and or what needs to be done to make it safe
TURBL0W
Nov 16, 2005 08:58 PM
94DOHCGsr
Nov 9, 2005 03:28 PM
slow91crx
Oct 3, 2005 08:20 AM
krystianitr
Sep 22, 2005 09:51 AM
