rc 310 injectors enough for 8pounds on b18c1
I was told by a tuner that i would not be able to use 310 injectors for 8 pounds of boost on the greddy kit is this true? if so what injectors for 230-250 hp? also it is being tuned with hondata s200 if that changes anything.
You could probably get by with bumping the base fuel pressure a few psi. But just for reference, I was hitting near 90% DC with 310's on a SOHC D16Z6 @ 8psi. We're moving up to 550's soon.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by si2die4 »</TD></TR><TR><TD CLASS="quote">310 are cutting it
Get yourself some DSM 440's or 450's
Not with Hondata.
</TD></TR></TABLE>Not with Hondata.
I am running the 310cc injectors right now. As long as you have a aftermarket fuel pump, and an adjustable fuel pressure regulator than you will be alright. So you can use em if it comes down to it. But i would reccomend running bigger, my situation came down to the last minute so I ran the 310's and it came out fine. I have 460cc injectors for sale if your interested.
bootlegtrader
10
Sep 19, 2005 05:40 AM
