GSR brakes on EG HB
Old Dec 16, 2001 | 03:54 PM
Cory man's Avatar
Default GSR brakes on EG HB
What exactly do I need? Just the knuckles with all GSR braking components? Thanks
Old Dec 16, 2001 | 04:05 PM
WykidEH's Avatar
Default Re: GSR brakes on EG HB (Cory man)
All you need are the complete front hubs from a Teg. It's all bolt-on. . . .
Old Dec 16, 2001 | 06:29 PM
chad's Avatar
Moderator
Default Re: GSR brakes on EG HB (WykidEG6)
will 90-93 integra brakes work on an eg?
Old Dec 16, 2001 | 07:02 PM
WykidEH's Avatar
Default Re: GSR brakes on EG HB (chad)
Front or rear? The rear will and I think the front will too.
Old Dec 16, 2001 | 07:16 PM
kent, clark's Avatar
How much would a full brake swap (F/R) cost and what cars are good to get the parts from?
Old Dec 16, 2001 | 07:23 PM
90accord1's Avatar
Default Re: GSR brakes on EG HB (kent, clark)
whole thing should cost 5-600, the 90-93 teg brakes do work all around i think, i knwo the rears work but offset the wheel out a little.
Old Dec 16, 2001 | 07:27 PM
Is it the same for an EJ (EK )
Old Dec 16, 2001 | 08:13 PM
WykidEH's Avatar
Yes, it is the same but, you'll have to use your rear lower control arms. By the way, I have a set of '95 GSR front hubs that're complete(hub, caliper, disc and lines). I'll sell them for $150.00+S/H. . . . .
Old Dec 17, 2001 | 03:56 PM
Sounds like a decent price but I don't have the money right now to buy them...I would post that in the H-T classifieds if I were you
Old Dec 18, 2001 | 06:48 AM
EG-cellent's Avatar
www.ImportAutoSalvage has them for 100.00 plus shipping
[Modified by EG-cellent, 3:50 PM 12/18/2001]
Old Dec 18, 2001 | 11:57 AM
hatchy's Avatar
Default Re: GSR brakes on EG HB (EG-cellent)
I asked the same question a few weeks ago before I did the swap. Here is what you need:
Front: Knuckle, rotor, caliper, pads, new brake lines. If you want a sway bar, you'll need the lower control arms
Rear: Caliper, rotor, pads, brake lines, rear trailing arm, parking cables.
Old Dec 18, 2001 | 12:58 PM
Are you talking about front brake conversions?
Old Dec 18, 2001 | 12:59 PM
Default Re: GSR brakes on EG HB (hatchy)
Yep, that seemed to cover everything except for the master cylinder and proportioning valve, I think.
meric0786
Apr 3, 2007 05:58 PM
Jmunk
Apr 17, 2005 10:27 PM
ea_hatch
Dec 4, 2004 08:03 AM
1CiViC1
Feb 15, 2004 06:55 PM
newspeedR
Jul 16, 2001 12:16 PM
