Help.... No spark. ICM and Coil are OK
I have a 1992 Civic Si and a couple of weeks ago I started it with a plug wire disconnected. It started, but ran rough so I realized it was disconnected within 10 seconds of it starting and turned the car off and replaced wire. Now when I went to start the car back, it would crank with no spark. I checked the coil and ICM and the coil was bad so I replaced it. Now the car still wont start. The coil is getting 12V and has a good ground and the plug wires are ok so I am led to beleive that it is the Cap and rotor. Also when I put my DVOM on the blk/yel wire and the second wire on the cap, and spin the rotor, there is no continutity so I beleive the rotor is not making contact with the cap. Is there a way to check that I am getting power out of the spring on the coil? DO you guys have any idea of what it could be. Its getting cold in Jersey and I need my ride. Any help is appreciated.
Hey Patterson I had something similar, check the resistance between the point where the "spring" contacts the cap and the center conductor (where the rotor makes contact with the cap) It should be a couple of OHM's Like 2.something. Just take off the cap turn it over and put a meter across theese two points. If it shows "OL" Its an open circuit, if there is no resistance, well I really don't know what that will cause either way trash it and get a good quality cap. I had to change two coils 'cause of cheap pep boys replacements
The rotor never makes contact with the cap anyway - so don't worry about that 'open' measurement.
Why don't you think it could be the igniter - you didn't say you replaced it?
Usually when one goes (coil/igniter), the other goes with it. Its been suggested to replace them as a pair, especially if they have high miles on'em.
And since you have a meter, does the Yel/Grn wire (ICM trigger) pulse while the engine is being cranked over? If yes, and you replaced the coil, I'd really suspect the igniter.
OK
Today, I replaced the ICM and charged the battery and still no spark. I am going for the cap and rotor combination tomorrow. in the mean time does anyone have any suggestions?
The yel/grn wire gets a constant 12 V when cranking.
OK. Over the past couple of days, I replaced the cap and rotor and gapped the spark plugs which were way off and lastly, I cleaned all the engine grounds and still it does not want to start. The coil I put on here is a used one which tested as a good coil. I am wondering if anyone has had a coil test good but not work. Also I got my hands on the helms manual and tested the Cyl pos, TDC and Crank angle sensors which were all OK. I also replaced my
P28 with a good P06 but still no luck. Anyone have any Ideas??
well when my car did that, i called honda and they told me that it was the ingniter module. They wanter like $220 bucks for it so i check out ebay and bought a whole new dizzy with a three year warranty for $200 shipped overnight. I would check out ebay, but if you have replace the ICM and the cap and rotors and the coil is fine. I would check the spark plug wires.
OK today I jumped the DLC and with the key in the on position, the CEL stays on so I am assuming the ECU is bad. Any input?
checked plugs and they were way to big of a gap but i am still at the drawering board so Please help. I will probably try another coil and if nothing happens, take it to a mechanic.
RobbyD
Oct 17, 2018 06:10 AM
VvPeachyvV
Jun 15, 2006 09:59 PM
