HOUSE CLEANING
NEW
Tokico Blues 96+ civic $200
Tanabe fornt sway bar 97 prelude $100
Bumper Lips
96-98 civic type R
99-00 civic Type-R
99-00 civic Mugan
92-95 civic rear lip
96-98 civic rear lip 40 each
autometer 5in tach w lite # 3903 $125
autometer 2 1/6 fuel pressure # 4312 $40
autometer 2 1/6 fuel pressure # 3312 $40
autometer 2 1/6 oil pressure #5721 $40
used
1 P13 (H22) AIR BOX-$30.00
3 B-SERIES PRESSURE PLATES-$10.00 EACH
2 d-SERIES PRESSURE PLATES-$10.each
5 B-16 OIL PUMP-$10.00
REAR MOTOR MOUNT BRACKET Assorted $30.00
1 SET OF FRONT STRUTS FOR EG 6- $30.00
2 SOHC VALVE COVER-$10.00 EACH
1 92-95 WIRING HARNESS-$100.00 inside and out with both fuse boxes
1 EG 6 MASTER CYLINDERS-$20.00 EACH one big res one reg
1 HONDA FACTORY JACK-$10.00
2 EG 6 FUEL FILTERS, LINES (USED)-$10.00 EACH
1 EG 6 AIR BAG HARNESS & COMPUTER - STEERING WHEEL-$100.00 COMPLETE
3 SOHC STARTERS-$20.00
1 EF AND EG 6 WINDSHIELD WIPER ASSEMBLY-$10.00 EACH
1 EF 8 REAR BUMPER SUPPORT-$10.00
3 EG6 OR DC2 FACTORY STRUT BARS-$10.00 EACH
2 EG 6 JDM AIR BOXES-$40.00 EACH
1 PR 4 LS AIR BOX1-$30.00
1 SET OF EG 6 ROLL UP WINDOWS-$20.00 EACH
1 P-13 FRONT HUB AND BRAKE ASSEMBLY-$50.00
1 REAR EG 6 DRUM SET-$20.00
2 EG 6 LOWER FRONT CONTROLL ARMS-$40.00 A PAIR
1 SET OF EG 6 MIRRORS (U.S.) $50.00
1 NOS FOGGER-$10.00
1 T25 GARRET TURBO $100
1 TYPE R RED VALVE COVER $40 SOLD
1 B16 BLACK VALVE COVERS $80
2 LS VALVE COVERS $40
1 B20 VALVE COVER $30
2 LS HEADS $50
1 B16A BLOCK AND CRANK $100 CLEAN micro polished crank
1 B16A SHORT BLOCK NEEDS TO BE SLEEVED $50
CUT EG DOORS W LEXAN $100
4 SETS OF PR3 CAM GEARS $20 EACH SET
3 B16A CAMS $50 EACH SET
TENZO DOHC VALVE COVERS ONE YELLOW $50 EACH new never installed
ASSORTED RODS AND PISTONS
Ross PistOns 86mm bore 14.1 comp never used 300
probe ctr spec pistons and rods 300 easly made 200 to the wheels used
Arias pistons 85.5 mm high comp customs $500.00w rings
hondata new stage 2 w/boost $500
Torco oil SR-1 10w40 $5.00 each
Torco oil SR-1 10w30 $5.00 Each
Torco oil SR-1 5w30 $5.00 Each
Torco oil SR-5 5w30 $8.50 Each
Buyers pay for shipping cost
call 562-307-6552
THANKS
Modified by Rated-R-Garage at 4:40 PM 11/3/2004
Modified by Rated-R-Garage at 10:58 PM 11/18/2004
Bumper Lips
96-98 civic type R
99-00 civic Type-R
99-00 civic Mugan
used
1 NOS FOGGER-$10.00
2 LS HEADS $50
call 562-307-6552
THANKS
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D »</TD></TR><TR><TD CLASS="quote">got an OBD2 timing belt crankshaft drive gear?</TD></TR></TABLE>
YES
YES
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superbeastcrx »</TD></TR><TR><TD CLASS="quote">i need cams for a b18a or a short throw shifter for an 89 crx</TD></TR></TABLE>
LS CAMS STOCK $30 SHORT SHIFTER $20 NEW
