Need advise ( just recieved my H22 swap )
Old Oct 12, 2004 | 11:14 PM
vtec92lude's Avatar
Default Need advise ( just recieved my H22 swap )
Well everyone I just recieved my H22 swap from http://www.venus-auto.com and everything looks to be real decent. I am missing the downpipe, but I called them immediatelly and they are shipping one right away. It appears my TPS sensor may be damaged, and the intake sensor is broken, normal valve cover damage, and a little dirty, but overall I am real happy. I was told the engine has between 30K and 70K kilometers on it.
The only concern I have is that I removed the valve cover and the oil residue is really dirty. Not quite sludge but real close. And it has left a black grime on the valves and stuff.
Does this mean the engine has been abused, or just neglected?
Is this a sign of high mileage?
I looked at the oil filter and it is a honda genuine filter, and the plugs are NGK, so I am assuming they are original. The belts ( timing, balance shaft, alternator, and water pump ) are all like new.
Is there anyway I can clean the oil residue and grime off without haveing to disassemble the head?
Should I return the engine?
Should I not worry about it and just do a couple oil changes right away?
By the way I removed the plugs and manually cranked it over and everything seemed normal. (no wierd noises, and the valves and springs moved freely)
I am planning on installing this engine friday but I don't want to do it if the engine isn't what it is supposed to be.
PLEASE HELP!!
Thank you all in advance!
Old Oct 12, 2004 | 11:33 PM
pentaq's Avatar
Default Re: Need advise (vtec92lude)
No you shouldn't worry that much This residue is due to the fact they kept the engine some time without running it. What we did when swapping a new engine? We poured it with the cheapest mineral oil, let it run for 20-30 minutes to heat up and clean the residue. Then we changed an oil filter and poured a new semi synt/synt (what you prefer) oil. And after 2000km we changed oil once again just to be sure. And it's running like a champ now.
Good luck with swap
Old Oct 12, 2004 | 11:47 PM
SKDRCR's Avatar
Default Re: Need advise (pentaq)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pentaq &raquo;</TD></TR><TR><TD CLASS="quote">No you shouldn't worry that much This residue is due to the fact they kept the engine some time without running it. What we did when swapping a new engine? We poured it with the cheapest mineral oil, let it run for 20-30 minutes to heat up and clean the residue. Then we changed an oil filter and poured a new semi synt/synt (what you prefer) oil. And after 2000km we changed oil once again just to be sure. And it's running like a champ now.
Good luck with swap </TD></TR></TABLE>
you can always follow up with a compression check as well
Old Oct 13, 2004 | 12:05 AM
vtec92lude's Avatar
Thanks for the help, but what is MINERAL OIL? I have never heard of it. Could you maybe tell me where I can get it? Is this dangerous?
Does any one know though if this means anything else (or could it)?
Thanks alot
Modified by vtec92lude at 3:27 AM 10/13/2004
Modified by vtec92lude at 12:44 PM 10/13/2004
Old Oct 13, 2004 | 12:23 AM
pentaq's Avatar
Just buy the cheapest oil avaliable nearby in 10W or 15W grade for engine flushing.
Old Oct 13, 2004 | 09:56 AM
jackstands's Avatar
Take pictures, lots of pictures. I swapped in my h22a and the wire harness looks like ****, cause i couldn't remember where some of the brackets went. Also, use this as an opportunity to replace all your belts, hoses and most of your seals and clutch/flywheel, if you've got the bank. I would also think about dropping the oil pan and cleaning the sludge off.
Old Oct 15, 2004 | 11:06 PM
PrettyLude's Avatar
since the motor is out it would be convenient to do it, and you might wanna try that seafoam
p1mmiz321
Mar 11, 2013 10:31 AM
sins
Feb 18, 2010 12:57 PM
jdmludeturbo
Jul 22, 2006 06:33 AM
ophdehEEzY
Apr 29, 2003 01:00 AM
Jonathan_ED3
Jul 25, 2002 05:37 PM
