will aftermarket pistons work without resleeving
Old Dec 16, 2001 | 03:27 PM
MisterB's Avatar
Default will aftermarket pistons work without resleeving
i was just in the prelude forum and i heard that you can not use aftermarket pistons in a h22 with out resleeving they also said this may also be true for F series motors does any one no if this is true i need new pistons for turbo but do not want to resleeve. any one running stock sleeves with custom pistons if so what are you running and how is it holding up???
Old Dec 16, 2001 | 03:40 PM
SOHCArchangel's Avatar
Default Re: will aftermarket pistons work without resleeving (cl4show)
the cylinder will have to be re-honed, but re-sleeved and honed if you are going larger than stock bore size
Old Dec 16, 2001 | 06:38 PM
MisterB's Avatar
Default Re: will aftermarket pistons work without resleeving (SOHCkordVTEC)
ya but do my sleeves contain FRM. I believe it stands for fiber reinforced metal/material. its the way the stock sleeves are constructed. h22 have it in the sleeves but i was wandering if the f series have it also...
Old Dec 16, 2001 | 07:33 PM
Honda318dx's Avatar
If anyone has a Helm's book, it will tell you what the sleeves are in there...
Well, I remember the 92-96 honda prelude (S model) had a F22A1 motor, and I have a prelude Helm's.. So I looked it up, and said NOTHING of having FRM sleeves, but it clearly says the H motors do have them, so I would think the F motors don't.. HTH
Old Dec 18, 2001 | 06:51 AM
2point6's Avatar
Default Re: will aftermarket pistons work without resleeving (Honda318dx)
You do have to resleeve the h22a for aftermarket pistons. If you don't, gaulling occurs due to the FRM cyclinders. On the f22a/b The cylinders are not FRM, so resleeving is not neccessary. Yor best bet is to contact a Piston Manufacturer like JE, Ross, or Weisco. they can tell you the specifics. Hope this helps.
Check out http://www.collectiveracing.net
[Modified by 2point6, 3:53 PM 12/18/2001]
Old Dec 18, 2001 | 07:09 AM
4doorH22's Avatar
Default Re: will aftermarket pistons work without resleeving (2point6)
Welcome to the board man, sound like you know your stuff.
Old Dec 18, 2001 | 07:19 AM
2point6's Avatar
Default Re: will aftermarket pistons work without resleeving (4doorH22)
Thanks for the welcome. I don't really claim to know much, but I have built several F series motors and I have built a couple of h series. I also built my 2.6ltr.
check it out at my site. http://www.collectiveracing.net Its in the members rides area/ blue and white accord.
Old Dec 18, 2001 | 08:13 AM
4doorH22's Avatar
Wow your car is insane. 2.6 liters of DOHC VTEC power? What rods did you use? I don't see rods in your extensive list of mods. What are you getting on the dyno?
Old Dec 18, 2001 | 08:26 AM
2point6's Avatar
Believe it or not I am actually using stock rods right now for N/A. I will be changing them out to eagle rods as soon as the car gets nitrous. 150+ shot Last dyno was on a different motor built by (R&D Dyno services :stay away: more on that later.) It was slightly bigger in displacement, but had less compression than I am running now. It laid down 208hp /177tq this was also untunned N/A. My new motor is not an R&D motor and I am expecting to get 230-240 whp/200 lbs/tq as soon as it is tuned. If you are curious about my bad experience with R&D, check out our message board at http://www.collectiveracing.net under product and service reviews. You must register to read it however.
Lifeeater46
May 26, 2007 04:17 AM
92_civic
Jun 2, 2006 11:37 AM
H22Prelude
Nov 9, 2005 02:16 PM
HeikDiesel
Oct 7, 2004 04:06 PM
GSteg
Sep 19, 2002 06:34 PM
