**B & H series garage sale**
Hey guys.
Here are a bunch of items I have laying around that I absolutely have to get rid of. If you have any questions let me know.
1. B18a1 Block 110k when it was disassembled, this block comes with the main caps and bolts, windage tray, NO CRANK. Can be honed, bored or sleeved no damage to it at all $120
2. Aasco aluminum flywheel used for 3k can be resurfaced or rebuilt with a new pad comes with a new pilot bearing. $130
3. Rc Engineering 800cc Peak and Hold injectors used for 3 k still have a flow sheet for them from when I bought them $250
4. B18a1 Head 110k when it was pulled complete with intake manifold, cams, valve cover, injectors, fuel rail. $80
5. B16a2 or B18c5 Intake manifold, extrude honed great for any application polished on the inside and outside with the head flange surfaced $150
6. Red NON Type R valve cover just painted red, clean it up and its ready to go, cut for adjustable cam gears. $40
7. Ls oil pan 1 small dent tight as hell very clean this HO is blingin $100
8. B16a Eagle Rods USED for 3k perfect shape nothing wrong with them torqued with a rod bolt stretch gauge $240
9. B16a Crank 45k when pulled perfect shape, just polish the journals and your back in business $100
10. Stock Ls pistons and rods 110k, ready for some arp bolts $50
11. B16a Coil and rotor used for 3k perfect shape $40
12. B series 3mm thick head gasket plate for lowering
compression, brand new $150
13. H series 3mm thick head gasket plate for lowering compression, used $90
14. Civic/Integra/Accord 2 gauge pillar pod used looks good still $20
15. 96 B18c1 Valve spring and retainer set $100
16. B18a1 flywheel never surfaced $20
17. B series charge pipes 2 mild steel 1 aluminum flanged for a greddy type s or type r bov. $120
18. Tial 40mm .6 bar spring $30
I will take money orders, paypal, cashier checks, no cod please.
If you have any other questions feel free to ask.
I will also be updating this with more items and pics later on. If you want more pics of a perticular item, let me know.
Modified by newgsr at 3:46 AM 10/19/2004
TonyR.Built
Jan 17, 2011 06:09 AM
