lil oil question
Old Oct 12, 2004 | 07:17 PM
FERIOkid's Avatar
Default lil oil question
i have a swapped sedan that a drunk bitch crashed into and it has a good d15b in it except for one minor problem. There is an oil leak and it appears to be comming from the rear main seal but the car is also burning oil...Does anybody know if having a bad rear main seal will cause the car to burn oil as well as leak it? And if not what do you think the cause might be? Any input or feedback would be great, I have searched and all i found was how to replace the rear main seal (which was helpful) but i need to know if it would potentially be something else. The motor also had a IACV code too... Thanks in advance HT..
Old Oct 12, 2004 | 07:32 PM
barroom hero's Avatar
Default Re: lil oil question (slowdx9585)
just rebuild it and find out.
Old Oct 12, 2004 | 07:34 PM
FERIOkid's Avatar
Default Re: lil oil question (barroom hero)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by barroom hero &raquo;</TD></TR><TR><TD CLASS="quote">just rebuild it and find out.</TD></TR></TABLE>
what i figured would be the common response...this is what i must do.
Old Oct 12, 2004 | 07:36 PM
thenick's Avatar
what a ******
jon try to source where the oil/blue smoke is coming from. if the blue smoke is coming out the exhaust its probably the piston rings in which case i would run a compression test to confirm it. if its coming off the actual block then i guess you've solved your problem
Old Oct 12, 2004 | 08:12 PM
Default Re: lil oil question (thenick)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thenick &raquo;</TD></TR><TR><TD CLASS="quote">
what a ******
ha, glad you care.
but back to my original response. I know that jon is thinking of doing a turbo set up on the d15, and he was going to rebuild the motor for that. if he plans to tear down the motor, he can find out what is leaking.
Old Oct 12, 2004 | 08:22 PM
thenick's Avatar
26 psi capable suzuki vitara pistons with a T3 super 60 all up in dat *** like whoah!
Old Oct 12, 2004 | 08:37 PM
FERIOkid's Avatar
i need some ****** money i'll tell you that much...
Old Oct 12, 2004 | 08:45 PM
thenick's Avatar
sell your girlfriend
Old Oct 12, 2004 | 08:51 PM
dunkd's Avatar
compression/leakdown tests are always a good start.
and a leaky rear main will not cause a car to "burn oil" (oil out the exhaust), only leak it.
Old Oct 12, 2004 | 09:25 PM
FERIOkid's Avatar
thanks everyone
Old Oct 12, 2004 | 09:34 PM
FERIOkid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thenick &raquo;</TD></TR><TR><TD CLASS="quote">what a ******</TD></TR></TABLE>
y0 Ryan is one of my best friends if you call him a *** again i will kick your ***** to your throat
Old Oct 12, 2004 | 10:05 PM
mikehawkBUiLT's Avatar
yea, i burn major oil too time for a swap
Old Oct 13, 2004 | 06:11 AM
FERIOkid's Avatar
Default Re: (EJcoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJcoupe &raquo;</TD></TR><TR><TD CLASS="quote">yea, i burn major oil too time for a swap</TD></TR></TABLE>
sucks doesn't it....the shitty part is, this is a swap from hmotorsonline
Old Nov 2, 2004 | 09:20 PM
Euro-Trash's Avatar
Default Re: (slowdx9585)
if it was a VW id say that its not leaking oil, its just marking its territory, at least thats what my car does
Skitso's CB7
May 5, 2011 10:22 PM
TXSR20DE
Feb 23, 2006 09:34 AM
ekcivic9
Sep 14, 2005 11:48 AM
danteisme
Jun 1, 2005 05:31 PM
92hondalude
Jan 12, 2005 01:59 PM
