Stock cams or Type S cams for turbo????
Old Oct 12, 2004 | 06:00 PM
sonnyboi612's Avatar
Default Stock cams or Type S cams for turbo????
i know about that whole overlap deal. But i want a different reason. Any suggestions?
Old Oct 12, 2004 | 07:15 PM
Mike95lude's Avatar
Default Re: Stock cams or Type S cams for turbo???? (sonnyboi612)
Type-S cams should be fine for turbo. They have higher lift, which is good and not much more duration I believe (correct me if I'm wrong). With extensive tuning I bet you can make great power, you can always dial out some overlap with cam gears.
Old Oct 12, 2004 | 07:22 PM
Default Re: Stock cams or Type S cams for turbo???? (Mike95lude)
thanks for your input... the reason why i ask this and not try both is because its a bitch changing them. (for me that is)
Old Oct 12, 2004 | 09:00 PM
PrettyLude's Avatar
lance ho with the hp racing civic runs off stock cams and made some crazy whp
Old Oct 12, 2004 | 10:22 PM
dr.bushpusher's Avatar
Default Re: (PrettyLude)
If you're gonna spend the money on cams for a turbo
you would be better off getting a set of custom grinded ones
made specifically for a turbo application.
Old Oct 13, 2004 | 06:53 AM
Default Re: (dr.bushpusher)
reason i ask is because i have both sets laying around
Old Oct 13, 2004 | 05:03 PM
PirateMcFred's Avatar
Default Re: (sonnyboi612)
The stock and Type-S have the same overlap. The S intake cam opens the valves 5* earlier and the exhaust valves open 5* later for a total of 240* duration on each cam. So I would use the type-S but I would be weary of going over stock red line w/o spring upgrade.
Pirate
B16CivicSi00
Oct 4, 2009 04:21 PM
fastludeh22
May 14, 2004 11:05 AM
hks3630
Jul 27, 2003 11:54 AM
4ghatch
Feb 2, 2003 09:36 PM
MysteriousGSR
Apr 15, 2002 06:47 PM
