Running lean/rich? help! (throwing codes)
Old Oct 12, 2004 | 05:31 PM
TurboHatch00's Avatar
Default Running lean/rich? help! (throwing codes)
A little background:
I just got doing a head swap on my 2000 dx hatchback to make it sohc vtec, instead of sohc non-vtec. I also put the edelbrock complete turbo kit on at the same time.
Problem:
When it was all said and done, I am pulling a couple of codes. 3, 23, and 45, which is, if im not mistaken, Map sensor is getting a high input, Knock sensor problem ( I don't have a knock sensor ), and I'm running rich or lean. Decided I've done enough to this car, I wanted to figure out what was wrong with it, and have someone else do the work, I took it into a local shop. They told me my timing was off by a lot. They set there gun to 16 or something and i saw that it was off. But the said I had to get an ajustable cam gear to fix the problem, can't I just adjust the distributer? Will this fix the problem? Help!
Symptoms:
1. Car stumble upon acceleration and idle on start-up.
2. Car backfires when given a lot of gas.
3. Car actually wouldn't let me give it gas on the highway when was pretty fast it eventually would die down everytime i tried to give it gas. I had to turn the car off and restart it and the problem was fixed. Wierded out!
*I checked my spark plugs, they look pretty red believe it or not. and had just a little black around the rim. ( not oil )
Modified by TurboHatch00 at 12:23 AM 10/14/2004
Old Oct 13, 2004 | 11:19 AM
Default Re: Running lean/rich? help! (TurboHatch00)
bump
Old Oct 13, 2004 | 04:55 PM
bump anyone!?
Old Oct 14, 2004 | 06:42 PM
ttt
Old Oct 14, 2004 | 06:48 PM
Tuesday Club's Avatar
I'm not too familiar with boost, so I cannot do too much but.....Why do you not have a knock sensor? Unless you are running a program that eliminates it, it will throw a code etc. As for [ignition] timing, yes, you can set it with the distributer. Where is your MAP sensor located? I do believe that boost will affect its readings if not placed properly, correct? Someone more familiar with boost needs to chime in....
Old Oct 14, 2004 | 06:53 PM
bgoetz's Avatar
Damn that sucks that is why you do one thing at a time. good luck
Old Oct 15, 2004 | 04:10 PM
Default Re: Running lean/rich? help! (bgoetz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bgoetz &raquo;</TD></TR><TR><TD CLASS="quote"> good luck </TD></TR></TABLE>
Thanks man, anyone that has a suggestion let me know please! I'm pretty desperate for a responce right now.
Old Oct 15, 2004 | 04:42 PM
chad's Avatar
Moderator
single camm'rs dont' have knock....
second...what head did you use?
92-95 sohc vtec's cam timing is different...like 8 degrees....
Old Oct 16, 2004 | 02:35 PM
Default Re: Running lean/rich? help! (chad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad &raquo;</TD></TR><TR><TD CLASS="quote">
I did the d16y7 block with the d16y8 head. All is 2000.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad &raquo;</TD></TR><TR><TD CLASS="quote">single camm'rs dont' have knock....
I'm pulling a code for the knock sensor. . . .
Old Oct 16, 2004 | 02:41 PM
ABK's Avatar
ABK
y8s have knock sensors. I think he is running a y8 ecu. I would just change over to obd I ecu with uberdata. Also with timing go by yourself a timing light and jump the connector and check your timing. Usually if your timing is off by a tooth your car won't even start, and if it does you will have a hard time running it. I think they are feeding you BS. Just adjust the timing with a dizzy.
Old Oct 17, 2004 | 04:43 PM
mugencivic99's Avatar
hey man.. runing boost will cause u some trouble with the intake u need a missing link to fool the computer to not read boost and check you timing make sure u got the right timming belt also,, it would help u alot if u got a jumper and went to obd1.. u can use a 92-95 vtec computer witch is a p-28.. it will get read of some of your sensors and make it run a lot smoother,, if it still runs a little like it;'s falling own it;s face then u are not getting enough fuel in boost, get a gauge and watch and see what it does mine was rich before vtec with a gsr computer at vtec it would start to lean at boost it would fall own it;s face,, i need more fuel.. hope this helps.. if u need any thing let me no....
ps air to fuel gagues will help..
Old Oct 17, 2004 | 05:28 PM
ABK's Avatar
ABK
Default Re: Running lean/rich? help! (mugencivic99)
air fuel gauge is a piece of ****.... need wideband if you wonna test that.
Old Oct 18, 2004 | 10:21 AM
Default Re: Running lean/rich? help! (ABK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ABK &raquo;</TD></TR><TR><TD CLASS="quote"> Also with timing go by yourself a timing light and jump the connector and check your timing. Usually if your timing is off by a tooth your car won't even start, and if it does you will have a hard time running it.</TD></TR></TABLE>
I adjusted the dizzy and fixed my timing, and it just idles higher or lower accordinglly. It still has all of the symptoms described in the first post though.
However! I just got another code reading an iacv fault. Could the signs above be early signs of a bad iac valve? is therhe a way to clean it or anything, to delay the process of buying a new one?
Modified by TurboHatch00 at 8:06 PM 10/18/2004
Old Oct 18, 2004 | 10:43 AM
Frozen E's Avatar
H-T White Ops
Missing link MAP bypass for you high MAP CEL.
Old Oct 18, 2004 | 11:05 AM
Default Re: (IslandSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IslandSi &raquo;</TD></TR><TR><TD CLASS="quote">Missing link MAP bypass for you high MAP CEL.</TD></TR></TABLE>
Thank you, i forgot to mention the shop also suggested this. Anymore suggestions?
Old Oct 18, 2004 | 11:49 AM
ABK's Avatar
ABK
Default Re: (TurboHatch00)
take of the iacv
clean it off
ohm it out (it's a solenoid) see if it's good.
Old Oct 20, 2004 | 05:35 AM
crx_88_si's Avatar
you never mentioned.. what kind of fuel management are you using?
obd-2 cars tend to be VERY picky towards any changes. I would get a obd2b-obd1 harness, use a p28 and run uberdata. or alteast the AFC w. 450cc injectors.
Old Oct 22, 2004 | 06:46 AM
Default Re: (crx_88_si)
Alright, will do, keep posted though see if this doest fix my problems!
Old Oct 24, 2004 | 11:29 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si &raquo;</TD></TR><TR><TD CLASS="quote">you never mentioned.. what kind of fuel management are you using?</TD></TR></TABLE>
With the Turbo kit itcomes with a turbo link management system.
Old Oct 24, 2004 | 11:31 AM
I talked to a technician who noticified me that it was my map sensor and that this was a common problem with the edelbrock turbo kits. I'm just gonna have to buy on and keep my fingers crossed i guess.
averyvm
Engine Management and Tuning
Jul 4, 2014 01:49 PM
rhartman0922
Apr 17, 2011 05:51 AM
jakop92
Jan 11, 2010 06:25 PM
ThomasMassengill
Sep 14, 2002 01:02 PM
stizzit
Jan 24, 2002 08:30 AM
