crazy tachometer
Old Oct 12, 2004 | 05:19 PM
Scubster's Avatar
Default crazy tachometer
hey everyone, my tach works fine until i hit 6000 rpms then it falls to zero. The car runs fine and the engine still revs but the tach goes to zero. After i let it rev down. It will jump back to 6 grand and go down from there. So basically it doesnt work after 6 grand. Any suggestions? Anyone have this problem?
Old Oct 12, 2004 | 07:09 PM
tblazak's Avatar
Default Re: crazy tachometer (AllM0tadc2)
Try checking all of your ground wires for starters, then your fuses. when all else fails try your friend's cluster... =P
Good luck
Old Oct 12, 2004 | 08:09 PM
PrettyLude's Avatar
the ignitor might be going out.
Old Oct 12, 2004 | 10:49 PM
Scubster's Avatar
Default Re: (PrettyLude)
ive changed the entire distributor and it does the same thing, so it cant be the ignitor
Old Oct 13, 2004 | 12:20 PM
PrettyLude's Avatar
well check the wire, if you using wire taps, there is a possiblity that the wires didn't cut through all the way, its somewhere in ur wiring
C1V1Chatchi
Jul 11, 2006 05:25 PM
itsJDMyo
May 28, 2004 07:00 AM
Mantis88ls
May 23, 2004 09:13 PM
DCx2xNV
Mar 4, 2002 10:45 AM
