rod bearing install. plz help
Old Oct 12, 2004 | 04:39 PM
hatchedzex's Avatar
Default rod bearing install. plz help
alright i got a problem with my #4 cyl(turbo single vtec z6 with stock internals on a 99ex block), i had a bad bearing on the rod (low oil and no warning light), so i replaced it, and its still ticken and prematurely wearing the rod bearing over the course of 5 minutes idle time, i see this plastiguage and number matching table in my book, but the bearings i had bought were standard and dint have the color code. so i dont think im settin the right bearings in. any info will be greatly appreciated
i also replaced the rod because after measurement the rod was slightly ovaled out. the old rod had a number 3 stamped on it and the new one has a number 2. i dunno if that matters but just more info.
Old Oct 12, 2004 | 05:10 PM
civic-4-ges's Avatar
Default Re: rod bearing install. plz help (hatchedzex)
Umm is the crank scratched??
Old Oct 13, 2004 | 09:32 AM
hatchedzex's Avatar
Default Re: rod bearing install. plz help (civic-4-ges)
no its polished to a mirror shine, the rod never came in contact with the crank, always had a bearing between the two
Old Oct 13, 2004 | 09:34 AM
Kamin's Avatar
did you check the clearances between the crank and the new rod? with this unknown bearing you put in you could have already spun it.
Old Oct 13, 2004 | 09:36 AM
WAFFLES's Avatar
Default Re: rod bearing install. plz help (Kamin)
sounds like a spun rod bearing.
Old Oct 13, 2004 | 03:01 PM
hatchedzex's Avatar
Default Re: rod bearing install. plz help (WAFFLES)
the bearing hasent spun, its like there is a gap between the rod bearing and the crank. i dont know how to measure the clearnes to get the right bearing in it
hardcore97
Apr 23, 2015 07:55 PM
AssPenny
13
Feb 22, 2014 07:51 AM
dj-t
Jul 2, 2009 08:48 AM
pjr710
Aug 18, 2008 11:18 PM
DBallz
May 9, 2003 12:13 PM
