checking for spark
Old Oct 12, 2004 | 04:15 PM
vxnine's Avatar
Default checking for spark
what is a way to check for spark?
Old Oct 12, 2004 | 04:27 PM
$300lude's Avatar
remove spark plug from engine, connect it in the plug wire and ground it against the engine where there is no paint to ensure a good grounding. Have someone turn the engine over and you should see it spark. Or you should be able to take the coil wire off of the coil, and put a screwdriver over the hole of the coil and have someone turn the engine over. This method doesn't check wires and plugs though. Be careful not to get hit by that spark , it'll knock your pecker in your watch pocket.
banginryder16
Nov 23, 2007 06:32 AM
vinuneuro
Oct 3, 2006 01:26 PM
skata89
May 21, 2006 03:32 PM
trianglegreg
Oct 26, 2005 06:18 PM
Allstar
10
Mar 28, 2002 07:04 PM
