Which axles to use h22 accord swap
Old Oct 12, 2004 | 04:13 PM
AVcTcEoCrd's Avatar
Default Which axles to use h22 accord swap
ive got a 96 EX Accord. swapped a jdm h22 and had prelude axles in. both boots went bad, so i bought 2 reman. axles from an import auto parts place. I noticed before that i was getting a knockin sound that seemed like it was the exhaust swayin due to not being hung, cuz of the way i had it done(which will be hung soon) but thats not the problem, i raised my car today to start replacing axles, and i hit my wheel and it had some play in it. so i grasped the wheel and shook it, and the wheel, rotor and hub assembly had quite of bit of play in it, like the axle nut wasnt tight. so i put an impact gun to it, and it did no good. so i said to myself, maybe jus replacin it will help. NOT. finished up the axles and tightened new nuts down.....still that play in the assembly . The question is, WHAT ARE YOU 5TH GEN ACCORD H22 GUYS USING FOR AXLES?? I think imma try some accord axles and see what it does, unless someone can tell me differently. Thanks in advance everyone!!
Old Oct 12, 2004 | 04:15 PM
rudeman85's Avatar
Default Re: Which axles to use h22 accord swap (AVcTcEoCrd)
It sounds like its your front wheel bearings, have fun with that one...
Old Oct 12, 2004 | 04:22 PM
91wagon's Avatar
I think that you should use axles from a 5th gen. 5 speed accord.
Old Oct 12, 2004 | 04:57 PM
jdmh22acord's Avatar
I was using accord axles for the first little while, but I kept snapping them at the track.
Since I switched to h22 prelude axles I haven't broke any.
They are stronger, and actualy made for the horsepower so I think that is the best way to go.
Old Oct 12, 2004 | 06:06 PM
AVcTcEoCrd's Avatar
Default Re: Which axles to use h22 accord swap (jdmh22acord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmh22acord &raquo;</TD></TR><TR><TD CLASS="quote">I was using accord axles for the first little while, but I kept snapping them at the track.
They are stronger, and actualy made for the horsepower so I think that is the best way to go.</TD></TR></TABLE>
thats what i thought too, but it doesnt seem like they are working out fitment wise for me, im gonna take another look at it tmw and see whats up with it. thanks though
Old Oct 12, 2004 | 10:43 PM
AVcTcEoCrd's Avatar
anyone else have any ideas??
Old Oct 12, 2004 | 10:49 PM
raceACCORDingly's Avatar
normally people use the accord axles.
Old Oct 13, 2004 | 05:14 AM
v4lu3s's Avatar
RTFM
prelude axles are too long and bind that is why you use accord axles. and accord axles can handle the power, unless you induce wheel hop, at which point most axles break.
i have had OLD used accord axles take 210 whp and 205 lb/ft of toque without an issue.
Old Oct 13, 2004 | 07:11 AM
KTeller8's Avatar
Default Re: Which axles to use h22 accord swap (91wagon)
96 accord with h22
used accord axles
Old Oct 13, 2004 | 02:21 PM
AVcTcEoCrd's Avatar
Default Re: Which axles to use h22 accord swap (KTeller8)
well i see most people use accord axles, but i got hte prelude ones to work today, all it was was that the hub was not totally pressed in. its all good now and drives wonderfully. thanks for all input everyone.
ricedaccord
Jun 16, 2011 01:12 AM
philafelman
Honda Civic (2006 - 2015)
Feb 4, 2008 06:15 PM
BBallz24
Jan 10, 2008 05:10 PM
typertn
Jan 9, 2005 03:24 PM
kurt.
Sep 1, 2002 02:32 PM
