b18c1 crx hf car still not starting help
Old Oct 12, 2004 | 03:23 PM
deftones0817's Avatar
Default b18c1 crx hf car still not starting help
K so i put a brand new distributor on it and the car still isnt starting...im thinking im fucked it turns and turns and it sounds like it wants to start but its still not starting...im getting spark and fuel.
DEF
Old Oct 12, 2004 | 03:48 PM
Rywire's Avatar
Default Re: b18c1 crx hf car still not starting help (deftones0817)
Check grounds, are you sure you got spark?
Old Oct 12, 2004 | 03:53 PM
$300lude's Avatar
yeah, check grounds. I left the ground off a d15b7 I had a few years ago and it did the same thing. It was the one that goes from the valve cover to the frame.
Old Oct 12, 2004 | 04:02 PM
HamiltonRex's Avatar
Default Re: ($300lude)
Timing is what you need to check last, make sure plugs are in the right order.
Old Oct 12, 2004 | 04:04 PM
Default Re: (HamiltonRex)
from back of motor to front its
12
34
on dizzy right?
I think ill recheck timing again tomorrow but im positive its dead on ive checked it 3 times now pulling timing belt off and reseting it. I check thermostat housing ground it actually was on there i must have been tired and forgot i put it on so i have 3 grounds.
1 engine harness to thermostate housing
2 front of car to valve cover and head
3 ground wire to for batter i think to chasis and to transmission.
DEF
Old Oct 12, 2004 | 04:45 PM
$300lude's Avatar
beleive it's:
looking at the back of the dis. cap
34
12
Old Oct 12, 2004 | 04:58 PM
yeah i just checked that i had wires in wrong but i fixed it and i have spark i had my mom come crank car while i did screw driver test. So im getting spark and you can smelll the fuel. How much does cam timing is retard would car just turn and not start?
DEF
Old Oct 12, 2004 | 05:18 PM
$300lude's Avatar
this is just a shot in the dark, but I re-read your original post and I see you replaced the distributor. I know it is supposed to only go in one way, but I know a guy who had a F22 and his mechanic told him he had to turn the dist. shaft and then install it. Follow me? But if you were already having this problem prior to installing new dist. then disregard. I have to do more thinking on this.
Old Oct 12, 2004 | 05:36 PM
$300lude's Avatar
Does that engine have a mass air flow sensor? If it does, then is your air intake connected? Still thinking.................
Old Oct 13, 2004 | 01:38 PM
found the problem the cam gear i put on it had the timing marks wrong...so i put the oem cam gears back on and reset timing the car started...now i just need to bleed the coolant system since it got hot really fast...
DEF
pictures when im done tonight.
Old Oct 13, 2004 | 02:27 PM
Default Re: (deftones0817)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deftones0817 &raquo;</TD></TR><TR><TD CLASS="quote">found the problem the cam gear i put on it had the timing marks wrong...so i put the oem cam gears back on and reset timing the car started...now i just need to bleed the coolant system since it got hot really fast...
DEF
Knew it was timing
Old Oct 13, 2004 | 07:04 PM
Rywire's Avatar
So its running good?? Congrats!! PICS
thekooler
Aug 5, 2011 05:37 PM
thekooler
Aug 2, 2011 08:54 PM
VTEC_PRODUCTION
Apr 7, 2007 01:55 PM
scottcal
May 24, 2004 12:23 PM
hondaboyturbo
Jul 17, 2002 10:11 AM
