How are people Doing their Intercooler piping on a D16Y8
Old Oct 12, 2004 | 11:49 AM
00BoostedD16's Avatar
Default How are people Doing their Intercooler piping on a D16Y8
I have everything figured out except the part by the throttle body where the IAT sensor goes into the intake pipe and where the hose going to the FIA control Valve is. So basically, how are you guyz going about integrating these things into your IC pipe. If you have pictures that would help alot!
Thanks
Chuck
<U>Final solution I came up with:</U>
Solution for Hoses going into the charge pipe:
i went to lowes and bought a 3/8" X 1" long metal spacer and drilled a 3/8" hole and welded it in place.
Solution for the IAT sensor.
1.)Go to ace hardware and go to the section where they have the screws and stuff.
2.)Look for the "rubber gromet" tray, (Pull it out, get one or two with an Inside diameter of 5/16", outside diameter of 5/8", thickness of 1/4" and grove diameter of 7/16")
3.)Now you need another rubber oring of the same thickness and internal diameter (i used a DSM oring i had laying around from my injector install, it was the oring that goes over the pintel of the injector) if you dont have one you can get one at ace while your there, or just use another rubber gromet.
4.)Now drill a 1/2" hole in the charge pipe
5.)put the rubber gromet in
6.)put the other oring you bought (or rubber gromet, which ever you are using) onto the IAT sensor to space it out so that the prongs at the end of the sensor grab the rubber gromet on the charge pipe and hold the sensor in there.
7.)then push the sensor into the hole, it's tight so it maybe take some pressure. It should not leak at all, if you are unsure slap some glue around it.
Modified by 00BoostedD16 at 5:40 PM 10/19/2004
Modified by 00BoostedD16 at 5:41 PM 10/19/2004
Old Oct 12, 2004 | 01:53 PM
Anyone???? Come on I'm stuck!
Old Oct 13, 2004 | 08:38 AM
I know there are people that made intercooler piping for a OBDII car! Any help would be appriated!
Thanks
Chuck
Old Oct 14, 2004 | 09:08 AM
come on guyz, help me out!
Chuck
Old Oct 15, 2004 | 09:56 PM
Nameless RB26's Avatar
Default Re: (00BoostedD16)
What is an FIA control valve? I've never heard that term before on a Honda.
Drill a hole into the pipe for the IAT. Extend it if needed..
Old Oct 16, 2004 | 07:44 AM
It's the Fuel injection air control valve. I dont recall what exactly it does. Thanks for your help, i sat down last night with my charge pipe and my stock intake and looked at it for alittle bit and figured out what i was going to do.
Thanks alot
Old Oct 16, 2004 | 08:39 AM
.dave's Avatar
i HAS questions ?
I drilled a hole in my intercooler piping, put a piece of cut up vacuum tube to act as a gasket and shoved the IAT sensor through that. Don't know if it'll stay in under boost, but its damn hard to pull it out.
Old Oct 16, 2004 | 12:08 PM
Thats a good idea, i think im going to do something similar to that.
Old Oct 16, 2004 | 12:23 PM
Hey guyz, if your looking for connecting hoses to the charge pipe, i went to lowes and bought a 3/8" X 1" long metal spacer and drilled a 3/8" hole and welded it in place. I'll let you guyz know how exactly i go about doing the IAT sensor.
Old Oct 16, 2004 | 03:13 PM
Canuk_SiR's Avatar
I have pics, but I'm too lazy to host them on my site
Just drill a hole in your piping, and get a rubber plug from any hardware store, just make sure you can drill a hole in it for the air temp sensor. put the rubber plug in the hole you drilled in your piping and you're set. I've been running that for 2 yrs now with no leaks
Old Oct 17, 2004 | 03:49 PM
Brandon Clifton's Avatar
Ask MiKeAhOwSkI, I believe he can help you out
Old Oct 18, 2004 | 02:52 PM
Solution for the IAT sensor is to go to ace hardware.
1.)Go to the section where they have the screws and stuff.
also thank you to everyone that has helped me on this thread.
Thanks again
Chuck
PreludeJunkie91
Oct 3, 2018 11:22 PM
slickciv
May 26, 2005 07:47 PM
SRd240sx
Dec 15, 2004 06:07 AM
Boost Addict
Sep 24, 2004 10:12 PM
RedTegLS
Oct 14, 2003 04:12 PM
