blox vs. skunk2 intake manifold?
i've been looking into buying an intake manifold...ive been hearing alot about the blox manifolds....anyone have experience with them?....how should they compare to skunk2s?....im runnin an allmotor setup with basically bolt ons just for now if that matters....thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 300bones »</TD></TR><TR><TD CLASS="quote">you might want to check the wicked im as well
looks pretty good.</TD></TR></TABLE>
wicked IM=Blox IM
wicked IM=Blox IM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trustbuddy »</TD></TR><TR><TD CLASS="quote">
wicked IM=Blox IM</TD></TR></TABLE>
actually.....wicked=BLOX=Skunk2=they are all the same, buy the cheapest one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16C1 »</TD></TR><TR><TD CLASS="quote">
actually.....wicked=BLOX=Skunk2=they are all the same, buy the cheapest one.</TD></TR></TABLE>
Wicked has shorter runner than Skunk2!
wrong
blox is not the same as a skunk 2 intake manifold. if you look closely inside the runners you will see that the blox manifold is slightly bigger and has a smoother finish.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by myhatchrips »</TD></TR><TR><TD CLASS="quote">wrong
blox is not the same as a skunk 2 intake manifold. if you look closely inside the runners you will see that the blox manifold is slightly bigger and has a smoother finish. </TD></TR></TABLE>
How does Blox compare to an AEBS manifold?
blox is not the same as a skunk 2 intake manifold. if you look closely inside the runners you will see that the blox manifold is slightly bigger and has a smoother finish. </TD></TR></TABLE>How does Blox compare to an AEBS manifold?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cmGSR916 »</TD></TR><TR><TD CLASS="quote">but aebs doesnt have their manifold for the gsr out yet...am i correct?....does anyone know when they will?</TD></TR></TABLE>
Not yet, they say "soon" but they have been saying that for a while.
The blox/Wicked Intake mani is lighter and boast a bit better casting. The runners are smoother just a bit.
Im about to bolt one of these on my giizer motor in about a week.
dyno charts soon ASAP.
I have a skunk2 LS IM and a Blox IM. I will dyno the LS IM if you guys want to see the differeance.....I dont have a skunk2 GSR manifold so I cant compare the 2 unless some one wants to donate thier car for a day.....give me some one that has a skunk2 IM and Ill provide the rest and give you guys the results.......oh and by the way......Blox and skunk2 are 2 different manifolds....and wicked is a repackaged Blox IM
my buddy had the sk2 on his gsr and said it made a diff. i dont know how it compairs to the other 2 but he dynoed 168 whp w/ just ctr cams and head work with the sk2 im.
I have a Skunk2 intake mani on my B18b, and it performs very well, however I have to agree the worksmanship is not too great andI had to drill all the holes so it could fit on the head!
Skunk2
Performance
Craftmanship
Skunk2
Performance
Craftmanship
what do BLOX Im requires for installation...stuffs like cables, intake cable bracket, gasket..fuel rail support.....similiar stuffs like that any modificiation?
cuz i know for skunk2 you need stuffs i stated above....just wondering if blow bolt right on and doesn't require extra to make it runs close to perfect
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 10000rpm »</TD></TR><TR><TD CLASS="quote">the aebs is better you just need to smoothen the runners and use pwr 70mm T.B.</TD></TR></TABLE>
in terms of quality, the AEBS is crap.
The skunk2 isnt much better...
I havent seen the blox manafold yet.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by irev210 »</TD></TR><TR><TD CLASS="quote">
Agreed, but it does make more power than the stock ITR.
