failed cali smog
Old Oct 12, 2004 | 11:09 AM
95ex5speed's Avatar
Default failed cali smog
hey guys im new the the forum. I have an all stock honda civic ex 5 speed that failed smog in cali. The has no mods done to the car. It has 125k miles on it. the car runs perfect except on cold start up my rpm tends to fluctuate which indicated it could be the iac. The fluctuation goes away after the car is warmed up. I changed the oil 2k miles ago but i haven't drove the car in almost 4 months. The previous owner said he did the tune up before he sold me the car (122k). Like i said everything is stock right down the the paper filter (which is dirty). I only failed the HC and the NO at 15mph. Heres the results. Any help would be greatly appreciated.
15mph
RPM: 1883
CO2: 15.10%
O2: .13%
HC: 97 l 107 ( failed)
CO: .59 l .26 ( pass)
NO: 731 l 797 (failed)
25mph
RPM: 2051
CO2: 15%
O2: .03%
HC: 62 l 62 ( barely passed)
CO: .59 l .19 (passed)
NO: 798 l 225 (passed)
Old Oct 12, 2004 | 12:58 PM
aznboysrfr's Avatar
get a new cat?
Old Oct 12, 2004 | 01:10 PM
Kamin's Avatar
Default Re: failed cali smog (95ex5speed)
the HC number is probably related to the dirty filter, could help bring the NOX down too.
Old Oct 12, 2004 | 01:23 PM
95ex5speed's Avatar
for more info on the car. When i did the smog, the timing was set at 14 deg btdc. I'm wondering if that is the stock reading. Also many people believe i could have a clogged fuel injector, so i put some stp fuel injector cleaner and it made the car run much more smoother and have a better fuel economy. The car idles near perfect. thanks for the quick responces
Edit...... I pulled my spark plugs and they were worned down. So the previous owner lied to me about changing the spark plugs. I went to change the plugs ,wires, cap and rotor. Goinf to get it resmog tomorrow.
Modified by 95ex5speed at 6:24 PM 10/12/2004
Old Oct 13, 2004 | 09:37 PM
HmgLauj69's Avatar
nox it due to high temp in combustion camber, it could be lots of thing but often time it's carbon. try sea foam from napa, works wonders
Old Oct 14, 2004 | 11:09 AM
95ex5speed's Avatar
Default Re: failed cali smog (HmgLauj69)
would a clog cat cause a high NO reading?
Old Oct 14, 2004 | 11:32 AM
HmgLauj69's Avatar
carbon residue in your cylinders, there's a napa on thorton and cedar ask for sea foam
Old Oct 19, 2004 | 02:17 PM
95ex5speed's Avatar
well guys i went back the the smog shop and passed. The only thing i've done since the last smog is that i put in a new obd2 cat, new plugs,wires,cap and rotor and a new filter. I haven't changed the o2 sensor and the egr valve with probably contribute to the high HC and NO. I also didn't put the sea foam, but I would recommend the new owner to put it in. I really appreciate all the input i got from this forum. Now the car is smogged, its getting sold by tonight. Heres the results
15mph
RPM: 1926
CO2: 15.37%
O2: .03%
HC: 97 l 96 ( passed barely)
CO: .59 l .13 (passed)
NO: 731 l 535 (passed)
25mph
RPM: 2072
CO2: 14.96%
O2: 0.00%
HC: 62 l 44
CO: .59 l .05
NO: 798 l 81
I did the second smog 15 mins after i put the new cat.
Old Oct 19, 2004 | 02:18 PM
95ex5speed's Avatar
well guys i went back the the smog shop and passed. The only thing i've done since the last smog is that i put in a new obd2 cat, new plugs,wires,cap and rotor and a new filter. I haven't changed the o2 sensor and the egr valve which probably contribute to the high HC and NO. I also didn't put the sea foam, but I would recommend the new owner to put it in. I really appreciate all the input i got from this forum. Now the car is smogged, its getting sold by tonight. Heres the results
15mph
RPM: 1926
CO2: 15.37%
O2: .03%
25mph
RPM: 2072
CO2: 14.96%
O2: 0.00%
HC: 62 l 44
CO: .59 l .05
NO: 798 l 81
Old Oct 19, 2004 | 05:59 PM
StorminMatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95ex5speed &raquo;</TD></TR><TR><TD CLASS="quote">I haven't changed the o2 sensor and the egr valve which probably contribute to the high HC and NO.</TD></TR></TABLE>
EGR valve in a Civic EX?
Old Oct 19, 2004 | 06:00 PM
EGR valve in a 1995 Civic EX? I don't think they have one.
Old Oct 19, 2004 | 08:46 PM
Kamin's Avatar
Default Re: failed cali smog (StorminMatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StorminMatt &raquo;</TD></TR><TR><TD CLASS="quote">EGR valve in a 1995 Civic EX? I don't think they have one.</TD></TR></TABLE>
you are correct they dont.
Old Oct 20, 2004 | 12:17 PM
95ex5speed's Avatar
Default Re: failed cali smog (Kamin)
oh opps
trying2tune
Jun 11, 2015 07:15 PM
spermdoggy
May 25, 2012 06:20 AM
Xyphon
May 31, 2009 08:43 PM
mr.krits
Mar 18, 2009 12:03 AM
Pravo2
Jun 4, 2007 07:00 AM
