For those of you with a JDM D15B on the P08 ecu....
Old Oct 12, 2004 | 10:26 AM
spyderracing's Avatar
Default For those of you with a JDM D15B on the P08 ecu....
How did you get it to stop throwin code 1 (O2 sensor). I know the p08 is a one wire conversion, but I can't for the life of me find out how to go about doing this...
Old Oct 12, 2004 | 10:50 AM
DJ_SaNdOz's Avatar
Default Re: For those of you with a JDM D15B on the P08 ecu.... (spyderracing32)
I am not sure on that. I am running a P28, that i intend to have chipped to PO8 specs so that I could continue to run my normal O2.....that may not help you though. Sorry. I tried searching for you, but none of the O2 topics seemed to answer this. GL
Old Oct 12, 2004 | 10:52 AM
Default Re: For those of you with a JDM D15B on the P08 ecu.... (DJ_SaNdOz)
Yea everyone seems to be runnin p28's....
Old Oct 12, 2004 | 12:40 PM
TTT
Old Oct 12, 2004 | 01:57 PM
NatedoggAZ's Avatar
I am using a P08 - have no O2 codes - are you using a 1 wire O/2 or a 4 wire O/2?
Old Oct 12, 2004 | 02:35 PM
Default Re: For those of you with a JDM D15B on the P08 ecu.... (NatedoggAZ)
I'm still usin my VX 5-wire.
Old Oct 12, 2004 | 02:53 PM
Discosteak's Avatar
im using a cx harness
Old Oct 12, 2004 | 03:03 PM
Default Re: For those of you with a JDM D15B on the P08 ecu.... (BADEG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BADEG6 &raquo;</TD></TR><TR><TD CLASS="quote">im using a cx harness </TD></TR></TABLE>
Uhhhhhh thanks?
Old Oct 12, 2004 | 03:58 PM
91civicDXdude's Avatar
run a wire from the o2 sensor pin on the ECU to your 1 wire o2 sensor. couldn't be more simple.
Old Oct 12, 2004 | 03:59 PM
DJ_SaNdOz's Avatar
Default Re: (91civicDXdude)
but he doesn't have a 1 wire sensor, he has a 5 wire sensor. He needs to know how to re wire the sensor if at all possible.....
Old Oct 12, 2004 | 04:02 PM
And what O2 sensor do I use? The chopped one that came in my d15b, and solder, or should I get a new one? And If I get a new one, which one should I get?
Should I use clips for ease of replacement?
There is a whole slew of questions.... it's not THAT simple.
Old Oct 12, 2004 | 04:12 PM
egizzle8
Guest
Posts: n/a
Default Re: (spyderracing32)
Go get a one wire O2 sensor off a obd0 engine.
Old Oct 12, 2004 | 04:21 PM
DJ_SaNdOz's Avatar
Default Re: (egizzle6)
OBDO? Really? Is the plug the same? Is there not a one wire varient from an OBD1 Honda that is compatible, or is there no way to rewire his current sensor, or plug? Just curious.
Old Oct 12, 2004 | 05:16 PM
Ignitecivic's Avatar
Default Re: (DJ_SaNdOz)
i did a mini me on my cx which is a 1 wire o2 sensor and im running a p28 . i just tap 3 more wires so it can be a 4 wire o2 sensor. no codes for a year now.
Old Oct 12, 2004 | 05:20 PM
ABK's Avatar
ABK
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egizzle6 &raquo;</TD></TR><TR><TD CLASS="quote">Go get a one wire O2 sensor off a obd0 engine. </TD></TR></TABLE>
it could be a CX too, maybe some other ones too.
Old Oct 13, 2004 | 06:50 PM
Default Re: (ABK)
Junkyard CX O2 sensor? thanks.
Old Oct 13, 2004 | 07:05 PM
Jim Truett's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spyderracing32 &raquo;</TD></TR><TR><TD CLASS="quote">Junkyard CX O2 sensor? thanks.</TD></TR></TABLE>
That or a universal one wire o2 sensor. There should be an orange/blue wire in the o2 sensor harness, and it should go to pin D14 on the ECU. This is the one you want to connect the one wire o2 sensor to.
Old Oct 13, 2004 | 11:09 PM
jdmsiR20's Avatar
Default Re: (Jim Truett)
yeah, just run a single wire o2 sensor... not too difficult, but if you want it to be reliable and clean.....
then you'll need to pick up one in good working order, and attach it with the stock harnesses and possibly some solder/shrinkwrap... just to make it OEM looking...
Old Oct 13, 2004 | 11:17 PM
a1320honda's Avatar
Default Re: (jdmsiR20)
you can get a brand new 1 wire for cheap. beacuse they arent heated and are very simple. were talking like $15. go to a junk yard and fing an old school teg or civic and cut the 1 wire harness and there ya go, some heatshrink and solder. good as jdm
Drama13
Dec 28, 2012 05:47 PM
Markb16a
Dec 2, 2006 05:40 PM
spyderracing
11
Oct 5, 2004 03:58 AM
trooper0641
11
Sep 9, 2004 07:42 PM
Phaze2 Mike
11
Jan 4, 2004 09:38 PM
