Naturally aspirated or turbo?
Old Oct 12, 2004 | 08:01 AM
JDMallTHEway's Avatar
Default Naturally aspirated or turbo?
I have a JDM B16 with some fuel system upgrades, and edelbrock intake manifold, and an edelbrock 65mm throttle body. Do you think I should go turbo, or build the car for high compression???
Old Oct 12, 2004 | 08:48 AM
EX-T's Avatar
Default Re: Naturally aspirated or turbo? (JDMallTHEway)
The better question is....What do you want to do?
It's your car!!!!!!!!
Old Oct 12, 2004 | 11:00 AM
BlueTeg01's Avatar
all I can say is research all of the people who have asked the same question and look what people told them.......all and all it your car do what you want!! I'm building an NA Beast as we speak. GOOD LUCK!
Old Oct 12, 2004 | 02:14 PM
im_poor's Avatar
Default Re: Naturally aspirated or turbo? (BlueTeg01)
neither.. Supercharger
Old Oct 12, 2004 | 08:24 PM
PrettyLude's Avatar
all motor is just as expensive as turbo if not more. the results are harder to come buy as if it was a turbo, just crank up the boost
Old Oct 13, 2004 | 07:33 AM
Default Re: (PrettyLude)
you're probably right, and how else am i gonna get my car to sound cool :-p
Old Oct 13, 2004 | 09:05 AM
civicturbo22's Avatar
Default Re: (JDMallTHEway)
Turbo! definitely!
Old Oct 13, 2004 | 10:13 AM
BlueTeg01's Avatar
suggestion if you go turbo...do it right!! Build up your block, resleeve, low comp pistons, and even some turbo cams if you have the money. Then slap on a good turbo kit. If money isn't an issue try to get a Full Race turbo kit. PM Earl from full race and talk to him about your turbo goals!!
Old Oct 13, 2004 | 01:33 PM
Default Re: (BlueTeg01)
money is an issue, as I am a very poor college student :-(
Old Oct 14, 2004 | 06:28 AM
BlueTeg01's Avatar
Well since I know where your coming from with the money deal. All I'll tell you is to sleeve your block and throw a turbo kit on! Some people will argue with me about sleeving your block, but your a college kid and you need an engine that needs to be dependable when running boost~~!
Old Oct 14, 2004 | 07:52 AM
How much does that usually cost??? whoa, you're in pensacola too??
Old Oct 14, 2004 | 11:35 AM
PrettyLude's Avatar
important thing to remember you pay for what u get
Old Oct 14, 2004 | 11:47 AM
I hear that.
Old Oct 14, 2004 | 12:26 PM
BlueTeg01's Avatar
PM'd Yep I'm in Pensacola!
Old Oct 14, 2004 | 01:07 PM
HFP's Avatar
HFP
TURBO!!!
Old Oct 14, 2004 | 01:38 PM
SOhp101's Avatar
Chances are that most people are going to tell you to go turbo... there was a survey done in the GDD section on which one was preferred, and majority said turbo.
Old Oct 20, 2004 | 09:00 AM
supertran25's Avatar
N/A all the way!
Old Oct 20, 2004 | 09:03 AM
1fastVX's Avatar
Default Re: Naturally aspirated or turbo? (supertran25)
The question should be is what do you want to do with the car such as road race, drag, autocross...etc?
John
Old Oct 20, 2004 | 09:56 AM
Default Re: Naturally aspirated or turbo? (1fastVX)
drag/road....but mostly drag :-)
Old Oct 20, 2004 | 01:57 PM
DaZman69's Avatar
go turbo, you don't need to sleeve your f-in engine, your an idiot if you say you NEED to. Sleeving is by far the least important thing. Stock honda sleeves are good for ALOT of horsepower, save money by keeping the stockers and spend it on a good tune. Unless your looking at like 400whp and up, keep the stock sleeves. BTW going turbo is much much cheaper. And if your going drag, screw NA. NA is nice, but for drag racing FI takes the cake.
Old Oct 20, 2004 | 02:22 PM
Default Re: Naturally aspirated or turbo? (DaZman69)
badass, how much boost can the stock motor take SAFELY. keep in mind it's my daily driver.
Old Oct 20, 2004 | 05:07 PM
91integraLSVTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaZman69 &raquo;</TD></TR><TR><TD CLASS="quote">go turbo, you don't need to sleeve your f-in engine, your an idiot if you say you NEED to. Sleeving is by far the least important thing. Stock honda sleeves are good for ALOT of horsepower, save money by keeping the stockers and spend it on a good tune. Unless your looking at like 400whp and up, keep the stock sleeves. BTW going turbo is much much cheaper. And if your going drag, screw NA. NA is nice, but for drag racing FI takes the cake.</TD></TR></TABLE>
going turbo is cheaper.. n/a car beating a turbo car, priceless.
Old Oct 20, 2004 | 08:12 PM
ooairewreckoo's Avatar
go NA.
Old Oct 20, 2004 | 08:22 PM
93lsd's Avatar
all motor all the way
the_dxB16
Oct 19, 2008 07:35 PM
splickitysplat
Aug 18, 2006 06:02 PM
TrunksSupSJ
Mar 24, 2005 11:42 AM
Turbo Powa
Jun 7, 2002 06:21 PM
Hondasaurs
Nov 5, 2001 07:38 PM
